Thread: Starter relay switch.
    Unknown madwun's Avatar
    Stone Mountain, Ga
    Question Starter relay switch.
    What's up? I can't find the starter relay switch for my 91 ls. Can anyone give me a hand? I'm not havin any fun driving a 2002 Accord. Thanks...
    mdwun!
    starter relay switch lol...If your starter isnt engaging then its either in the ignition switch, or bad starter, Not a relay ...Hit the starter with a hammer or something heavy an hard as someone is trying to crank it, if it cranks then you will need a starter if it doesnt make sure its getting a signal to the ignition wire, an power to the BIG wire, its constent power...hope this helps Joshua
    push start ..lol
    Quote Originally Posted by mp82
    push start ..lol
    I am too fatt to do that shltt any more
    what he said is the skinny little wire that plugs into the started should get 12 volts (or light a test light) when someone is hold the keys in start/crank position. The big wire that attatches to the started with the 12mm bolt should have 12 volts (or light a test light) all the time because it comes straight from the battery.
    If the skinny wire does as posted u got ignition switch problems more than likely.
    If both test does as posted then u need a starter. (assuming ur stater is bolted down which is how the starter is grounded).
    Good luck dood!!
    what he said is the skinny little wire that plugs into the started should get 12 volts (or light a test light) when someone is hold the keys in start/crank position. The big wire that attatches to the started with the 12mm NUTshould have 12 volts (or light a test light) all the time because it comes straight from the battery.
    Good luck dood!!
    Fixed it for ya!!!
    Fixed it for ya!!!
    preciate that haws.
    preciate that haws.
    Just thought I would NICK PICK you!
    i knew it was coming.
