Thread: how to mount EP3 into EK hatchback. please help
    Default how to mount EP3 into EK hatchback. please help
    i really need some help on this. i've look on honda tech but the best it came up with is how to mount the ep3 seats into an em2. i seen members ride on here with the ep3 seats in the ek hatch and em1 coupe and please please please help me with this. pictures or instru is needed. and if you don't want to give up the info i'll pay you $50 to put them in for me.
    SoooperDooooperLS
    first how are you going to be paying? Cash, Check, or Money order?
    North Augusta, SC
    hmmm... where do you live? I never messed with changing out honda seats, but just put evo 8 seats in a 1g eclipse... wasn't fun, so figuring this probably won't be much harder... Do the brackets line up at all? can you take the rails from one seat and put them on the other? (we had to fabricate every bracket)
    Back to being stock and slow
    cash, i'm in clay co. the brackets doesn't line up. the mounting points on the floor of my hatch are space wider then the ep3 sliders on the two front holes. the rear mount space close to the door, the slider mount doesn't go over that bump. and the other floor mount spot the slider mount is too short to reach the floor mount spot at the center of the car. i just tried to switch out the whole bracket from my hatch seat to the ep3 but the side brackets are different so none of the screw holes even come close to each other. looks to me the best way to do it is to cut off the mount bracket off the ep3 sliders and weld in new ones to match up to the floor mount spots on my hatch. if there's any other way i would love to know.
    is better than you..
    Somewhere you're not
    requires making a custom bracket, involving cutting and welding..
    Quote Originally Posted by Krappy
    damn! okay doesn't anyone know any shop that can do this for me?
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Did you try the EM1 seat sliders on the EP3 seats??
    On the drum set!!
    Looked on HT and this is what I found
    http://www.honda-tech.com/zerothread?id=1959183
    This preson did a seat pan swap, hope this helps!!
