Results 1 to 14 of 14
Thread: B16A Turbo EG Idle is high...
    Duluth, GA
    Default B16A Turbo EG Idle is high...
    When the car is below normal operating temp the idle is fine...no matter what...but once it warms up:
    while I'm driving if I out the car into neutral the idle sits about 700 too high...EDIT:(SO ABOUT AT 1600 )then when I stop at a lght or stop sign etc...it will go back down...but in neutral and rolling the idle is higher...any suggestions?
    AKA THE BROWN MAN
    Kennesaw, Georgia, United States
    dude 700 is not a high idle i think you might idle so low that when you are in neutral and slowing down to stop your brake booster is keeping the motor running
    Duluth, GA
    no it's idling 700 OVER normal
    jupiter
    but you say when you are stopped that it goes back down huh??? that is weird. aliens. they are in your engine bay. lol sorry i wish i knew a real answer. i am just bored as fu ck in english class.....................
    West Staines
    vacuum leak?
    rolling idle is normally higher than resting idle, but 1600 is a little high. is it the car in your sig? boosted/tuned?
    Duluth, GA
    it is the car in my sig...its street tuned on crome
    depending on which version there are rolling idle settings and iacv settings that could be causing this. there are also ect idle targets. a lot of things come to mind, but i would look into those first.
    Duluth, GA
    maybe I should just get it dyno tuned
    dc5
    ATL, GA
    Are you running Hondata?
    known as Charles
    Quote Originally Posted by Captain-Obvious
    Single greatest post ever made.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    02 WRX patrick4588's Avatar
    warner robins
    **** i wish my rolling idle was higher. lol. if its idling normal when you are stopped, i wouldnt worry about it!
    GCO Member
    NRA Member
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    had the same problem... its a vacuum leak or bad IAC valve... or just need to clean it out?
    Look, i have a nice set for sell, check this out:
    http://240atlanta.com/forums/showthread.php?t=27950
    thx man
