Results 1 to 14 of 14
Thread: quick wiring question
    Need Parts!
    Canton
    Default quick wiring question
    ok my rca hook ups on my amp are both black and say input and output but my radio says left and right so, what i want to know is which one is which. this is probably a simple question to someone. will rep
    02 WRX patrick4588's Avatar
    warner robins
    it probably needs just one input. so go get a 2 into 1 splitter and be done. post a picture if you can
    GCO Member
    NRA Member
    Need Parts!
    Canton
    heres some pics
    http://images.google.com/imgres?imgu...%3Den%26sa%3DN
    What The Hell
    Kennesaw/Acworth
    pic is a little to small for me to tell anything
    Need Parts!
    Canton
    Quote Originally Posted by 90_ACCORD
    click on it and it gets bigger
    Hiram, GA
    It doesnt matter which way you look them up as their is no left or right stereo.
    BTW, I have heard some good things about US Acoustics. Let us know what you think of the amp.
    I GOT IT!
    Jan 2003
    Lithonia, GA
    i use to have a cheater usacoustic amp back in teh early 90's it did 150x2@4ohm 450x1@4ohm and like 800X2ohm. but the box stated different until i bench tested the amp and was like wow!!! so if the quality is still the same then its a solid amp.
    Hybridaccord
    Rude Lude Dude w/S2K JayKnight's Avatar
    NW GA...Ringgold !
    The INPUT side is for the signal comeing from the HU to your AMP. The OUTPUT side is so you can run another set of RCA cable to another AMP if you don't have more RCA Pre-Outs on the head unit. Since that amp is MONO, it will not matter which(Left or Right) get hooked up.
    Hope that helped.
    Later !!!
    Need Parts!
    Canton
    Quote Originally Posted by BanginJimmy
    had the amp hooked up before and loved it the best part is i paid 60 bucks for it
    Need Parts!
    Canton
    ok so even though i have two plugs on radio and amp it dosent matter wright? (better safe then sorry)
    Hiram, GA
    yea just plus them to either input jack and you will be fine.
    Need Parts!
    Canton
    thanks
    NW GA...Ringgold !
    Quote Originally Posted by EthanR
    Yep, just make sure that the RCA coming from the Head Unit is going to the INPUT side of your amp. Like I said, the OUTPUT from the amp is to add another AMP if you don't have multiple RCA PREOUTS from the headunit.
    Pretty simple.
    Later !!!
    Quote Originally Posted by JayKnight
    Pretty simple.
    Later !!!
    I think the question was already answered. By actual stereo people. Later, QD.
