Results 1 to 13 of 13
Thread: coolant temp sensor!? WTF
    Default coolant temp sensor!? WTF
    So my check engine light comes on the other day when I needed to go get my emmisions done and it's reading out high input coolant temp. sensor. I checked to make sure the wire was connected to the sensor and it was. Disconnected the battery to try and reset the code and it didn't work. So I replaced the coolant sensor and the light is still on!
    Went to autozone this morning to see if I could erase it and it came right back on. Anybody ever had this issue and how can/did you fix it?
    +reps for REAL advice
    Thanks
    badd sensor then, if you've done all of that and still no good signs.. try replacing a newer one on..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Are you sure you didnt mix plugs up?
    i'm pretty positive i havent mixed up any of the plugs. i'm gonna check it again tomorrow.
    youknowit- are you saying replace the sensor again?
    probably wires dont have a continuity contact. check that out shorted somewhere loose ends (hear it click in) leave battery attached and just take out ecu and 2-3mins then insert fuse back in,
    and that connector does have 2 connectors coming out of the harness right! one goes to the temp sensor and the other just slides in (plug up)
    /Oo ___A___ oO\
    |=_/_______\_=|
    So disconnect the ecu fuse for a few mins and then put it back in; and yea that does have the two connectors coming out of it like you said. This is the one that clicks
    u drive the car daily? iono but just thought maybe let the car run for about 1/2 hr and see if fan turns on when it's in operating temp. just a thought
    /Oo ___A___ oO\
    |=_/_______\_=|
    time to slap out the volt meter and get some reading.
    you wanna ghetto rigg it .. then take out the gauge cluster, and take off the light for the check engine .. bada bing, bada boom.. :0
    /Oo ___A___ oO\
    |=_/_______\_=|
    Yea I just went ahead and pulled the guage cluster out late last night to get the light. I'll get the emmissions test and put it back in. I don't mind the light being in there because its purpose is to warn you of problems.
    Quote Originally Posted by EG6
    yes sir and i'm having problems of my own.. wish mine probs was as easy as yours haha
    /Oo ___A___ oO\
    |=_/_______\_=|
    thats dumb it still will not pass emissions
    Quote Originally Posted by YouKnowIt
    If you take the bulb out, it will fail for that an still show codes in the ECU...You need to fix the problem, High Input means your getting to much Volts to the coolant sensor, most like is either wrong plug , or short to ground, or bad ecu
