Results 1 to 3 of 3
Thread: f.s./f.t. 1989 240sx with sr20det swap
    Default f.s./f.t. 1989 240sx with sr20det swap
    sold
    ok i got my car up for sale. it is a 1989 240sx coupe with a sr20det engine swap.
    heres a list of some of the mods
    sr20det redtop swap
    5-speed tranny
    s14 t28 turbo
    hks adjustable actuator
    greddy oil pan
    greddy oil filter relocation kit
    megan racing turbo header
    megan racing turbo elbow/ with adaptor for small 02 sensor
    project silvia downpipe with welded in 02 bung for wide band
    3'' high flow cat
    3'' exhaust with trust muffler
    greddy r-spl fmic
    enjuku racing hot pipe
    hks bov new style
    k and n m's racing air filter
    koyo radiator
    samco hoses
    circuit sports coolant tank
    14'' elec cooling fan
    enjuku racing cooling panel
    z32 fuel filter
    walbro 255 fuel pump
    redline mt-90 tranny fluid
    spec stage 2+ clutch 300 miles on it
    d2 coilovers with only about 5k miles with 2 autox on them
    Ichiba 5-Lug Front and Rear Hubs with new bearings
    front and back new front and rear drilled and slotted rotors by circuit sports
    z32 rebuit front calibers and pads
    new brake pads on the back
    gramlight 57c gold rims 17x8.5 +30 offset 800 miles on them
    rt-615 tires 800 miles on them
    one piece alumiun driveshaft from driveshaft shop with heavy duty u-joints
    ca18det vlsd with 4.3 gears
    s14 seats
    skyline steering wheel in ago shape
    aem wideband gauge
    autometer phantom boost gauge
    autometer phantom oil psi elec gauge
    autometer phantom water temp gauge
    apexi safc-2
    hks turbo timer with harness
    new ngk spark plugs
    rear ebay struat bar
    stainless steel brake lines
    the bad
    dash has alot of cracks
    dash harness needs to be wired up
    car needs paint and body work it is a 89 model
    could us some carpet(driverside has bad spot in it from someone using no floor mat)
    needs all the sensor from the kade tranny swapped on it.
    also where i the cold pipe is you need to make a cover for the hole there. the battery tray was rusted real bad so i cut all the rust out.
    i would drive this car anywhere. it is a good running car. i had this car for about 3 years now and it had a kade swap in itthen. and now i swapped the sr in because i wanted some boost again. it runs strong and fast for waht it is. the trubo spools nice and fast. the clutch is just getting broke in. the car still hase most of the a/c stuff inplace on car. i havent had it at the track to see what it would run yet. and it needs to be tuned if you turn the boost up. ask me anything you want to about it. heres some pics of it before i go tthe front bumper on it. i will take some more pics of it this weekend and post them then.im asking 6500 obo for it. i got more invested in it. serious buyers can test drive it. the car is located in attalla,alabama. im also looking for a 2 gen camaro. so i would think about a trade.
    p.s. if it goes for the asking price i will give the buyer some 550cc injectors,z32 maf with plug,and a front end brace(might install that this weekend).
    ca18det powered 240sx
    Senior Member Code-Aye's Avatar
    hahaha
    pm'd
    Quote Originally Posted by JDMmadness
    pm'd
    i replied to your pm.
    thanks
