I have for sale my system out of my truck, it is 2 mtx thunder 5500 12's i a custom sealed probox with an almani 1500 watt amp.
AMP specs:
* Soft turn ON/OFF
* High efficiency, aluminum heat sink
* Nickel plated terminals
* All models are bridgeable
* Class "AB" Technology MOSFET Protection circuits against Overload, Thermal, Reverse Polarity
* 1 OHM stable operation
* Remote gain knob
* RMS Power @ 4ohm: 175W x 2
* RMS Power @ 2ohm: 350W x 2
* S/N 90db
Speaker specs:
* Sensitivity: 92.9 dB
* RMS Power Range : 300 Watts
* Peak Power Handling: 600 Watts
* Impedance: Dual 4 Ohm
* Low Frequency response: 30 Hz
* High Frequency Response: 150 Hz
* Diameter: 12 Inch
# Asymmetrical Linear Drive Technology
# Aluminum Deposition, Carbon Filled Cone
# New Concave Dust Cap / Cone Assembly
# Spider Plateau Venting
# Folded-Window 16 Gauge Steel Frame
# Stitched Nitrile Butadiene Rubber (NBR) Surround
# 70 oz. Strontium-Ferrite Magnet with Protective Magnet Boot
# 1 3/4" Aluminum Voice Coil
# 428°F Voice Coil Wire Temp Rating
# Injection-Molded Polystyrene Gasket
# Radius Vented Pole Piece
# Woven Tinsel Leads
# Xmax: 0.53"
box specs:
Fits: '04 and Up
Ford F-150 Regular Cab
Holds (2) 12" subs.
Mounting Depth: 7"
Dimensions:
D (top): 6.25"
D (bot): 11.5"
H: 17"
W: 50"
Air Space: 1.45 cu. ft. per side
$450 OBO can seperate speakers as a pair and amp alone and box alone.
