Results 1 to 3 of 3
Thread: Antec True Power Trio 550w Power Supply
    Certified Gearhead GET8UP's Avatar
    Conyers
    Default Antec True Power Trio 550w Power Supply
    This power supply is in excellent condition.
    Specs
    Brand: Antec
    Model: TP3-550
    Series: True Power Trio
    Type: ATX12V
    Maximum Power: 550W
    Fans 1 x 120mm low noise cooling fan
    PFC Active
    Main Connector: 20+4Pin
    +12V Rails 3 x +12V
    PCI-E Connectors: 2 x 6Pin
    CrossFire Ready
    SLI Certified
    Modular: No
    Efficiency Up to 85%
    Over Voltage Protection: Yes
    Input Voltage: 100 - 240 V
    Input Frequency Range: 50/60 Hz
    Input Current: 9 A
    Output: +3.3@24A,+5V@24A,+12V1@18A,+12V2@18A,+12V3@18A,- [email protected],[email protected]
    MTBF: 80,000 hours at 50°C
    Approvals: UL, CUL, FCC, TÜV, CE, C-tick, CCC, CB
    Features:
    Connectors 4 x SATA connectors for Serial ATA drives
    2 x PCI-E connectors for PCI-Express video cards
    Features Three 12V output circuits provide added system stability
    Accurate power rating allows TruePower Trio to deliver its full rated power, 24 hours a day rated at 50ºC
    Fan Only power connectors allow TruePower Trio to control case fan speeds, reducing total system noise
    Dedicated outputs for stable output and less ripple noise
    Feedback loop circuits for tighter load regulation (±3%) to maintain accurate voltage to all components
    Heavy duty protection circuitry prevents damage resulting from short circuits (SCP), power overloads (OPP), over voltages (OVP), and under voltages (UVP)
    Power Factor value up to 99%
    Gold plated connectors for superior conductivity
    Manufacturer Warranty
    Parts 5 years limited
    Labor 5 years limited
    Price: $50
    Attached Thumbnails Attached Thumbnails -100_1241-jpg   -100_1242-jpg
    What part of Conyers? I go out that way every other week or so? Im needing a new PSU for my new vid card. Lemme know
    Conyers
