This is a brand new turbo, 60 trim with a T3 internally gated .63 exhaust side. As you can see the compressor housing is polished and has a 90 welded to the bottom. From what I've seen its good for just under 400whp. It was originally set up for a KA-T top mount but can be used for nearly any setup. Will need the wastegate actuator assembly and actuator which only costs about $120. Just need to get rid of this one since I don't see ever using it on any other projects. $400 obo Again, its brand new and has only been bolted to a manifold and then pulled for a different setup before the motor was even put in a car.
