Results 1 to 23 of 23
Thread: ls swap question
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Default ls swap question
    yes i am swapping an ls into a ej1 coupe and i need to know what shift linkage i need to use for it? its going to be a ls tranny and i have the stock d series linkage now
    98 Acura Integra LS-DD
    ??????????????????-project
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    you'll need the ls shift linkage
    TALKING ROCK, GA
    will any b series tranny
    a DC shift linkage will work...
    TALKING ROCK, GA
    an ls dc linkage will bolt right up?
    TALKING ROCK, GA
    also what if i decided to go with gsr or b16 tranny?
    you need any 94-01 integra shift linkage, doesnt matter what model as long as its from a 94-01 integra
    TALKING ROCK, GA
    thanks guys
    TALKING ROCK, GA
    ok what about axles? what axles do i need? any b series axles?
    bseries my friend, and also the half shaft also, b series motor mounts, especially rear motor mount.
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by 95egex
    either DA or DC just make sure u get the proper half shaft to match.
    TALKING ROCK, GA
    can i use b16 axles? i work at honda so i get a good deal on parts
    yes
    TALKING ROCK, GA
    sweet so i can just get axles for a 99 si and will work in an ls tranny?
    Yes, or an integra axle..
    TALKING ROCK, GA
    well i cant get good deals on acura parts only honda parts
    Norcross
    so just use the si ones then
    if a acura or honda came with a B series motor... you can use the axle from it, minus the type r. simple
    and crv
    The rear bracket yes not the mount!!! the mount on your stock d series works fine!!!! also you can use 99-00 B16 Si shift linkage also!!!
    Quote Originally Posted by YouKnowIt
    depends, there are some that didnt have the intermedit half shaft which is needed, so make sure you get that, bolts to the back of the motor, and into the tranny then axle slips over the interm.half shaft
    Augusta Ga
    since u can get "HONDA" parts use the 1995 Del Sol Vtec model Axles ..or the 99 civic SI axels ... use the 94-01 integra shift linkage . i have the halfshaft if you need it .. will fit the B16 and ls axles .
    93 sol Si
    95 sol S
    95 sol Si
    Im a killer
    u got all the parts for it already? I have a ls hatch that still in my car...runs perfect but im plannin to sell everything except the tranny.
