Thread: is my clutch gone??
    2_dr_integ
    Unhappy is my clutch gone??
    so i have a 96 Integra with 145k on it and it won't go in to gear at all. I replaced the slave cylinder about 4 months ago. I thought there might be air in the line so i bled it alot and still can't move only other thing i can think of is the clutch... Is that it or am i over looking something? Thanks
    respect the TEG
    YES
    TIME FOR UPGRADE
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    yep pimpin. Consider yourself in the market for a clutch.
    YES
    TIME FOR UPGRADE
    Quote Originally Posted by twinj
    JDM TYTE AnthonyF's Avatar
    They are cheap and easy to do.
    -Ant.
    The Carbon Fibered R6
    It's all about JDM.
    CA to GA
    Check the clutch master cylinder....check if the fluid is low and then check the clutch pedal to see if it is leaking fluid between the firewall and where it cable attach to the pedal....it usually leaks for all manual cars. If it is leaking, replace the CLUTCH Master cylinder (not the brake master cylinder, they are two different units), if you're cheap, then take it apart and clean the inside of the Clutch MC (usually gunk build up)....Then, flush the with dot3 or 4 brake fluid, bleed the system properly, and refill with dot 3 o4 brake fluid...Hope this helps ur problem.
