Results 1 to 14 of 14
Thread: ants in the car! need help asap.
    Default ants in the car! need help asap.
    my girlfriend drives a camry and there are ants all over the car. it started with a couple of black ants being found inside and outside the car, mostly around the door. we just cleaned out the car and sprayed some raid on the floormats and around the door. we also went through a pressure wash. all the ants were gone and than the next night we found hundreds of ants mostly on the hood and some around the door. there could be some inside the car but it was dark so we couldnt find any at the time. anybody have any experience with this? i need some advice asap. thanks.
    Trogdor!!! IOnlyLookStock's Avatar
    There's food or something sweet spilled in your car. Happened to me one time. Turns out I had a thing of kool-aid turned over under the back seat. I took mine to a carwash and let them scrub it for me.
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    Funk E. Fresh okra1981's Avatar
    West
    Park in a different spot and make sure there is no food in the car. They will die eventually. I've had minor problems every time I park in a certain spot at my apartment complex.
    Some say that his politics are terrifying, and that he once punched a horse to the ground...
    Stone Mountain
    you've heard of teh trunk monkey? well i suggest a trunk ant eater
    athens
    i've had this. check under the hood. i found a little freakin colony of the things. little white babies and all..pressure wash or spray poison.
    Senior Member G.C's Avatar
    Forgot
    fog your car . when it was in my old car there was a ant colony in my trunk.
    :idb:
    Loganville
    simple solution. . . . . . . . . . . . . . . Just place a lit match in the gas tank and await explosion.
    Ballin' on a Budget
    West Staines
    i had ants in the backseat of my Lexus i took a hose to those mother fuckers then wiped down the leather with a towel
    Atlanta, Ga
    gangster ^ haha
    FLOSSIN' MR.EM1's Avatar
    BUG BOMBS > ants
    FL
    Stang Mod slostang's Avatar
    Southside
    clean all the food, etc out of the car. roll the windows up. instert bug bomb.
    Hiram GA
    I had ants in the car once as well... all I did was cleaned the car really good and parked in a different spot for a couple days.
    E38 740i M fininfarina's Avatar
    I had once before,
    Change the place where you park now if you live in apartment
    make sure no food there
    kill all if you see any, then wait
    will be gone soon
    North Augusta, SC
    Quote Originally Posted by chip P.
    Back to being stock and slow
