Thread: Squeaky rolling noise
    It's all about JDM.
    CA to GA
    Default Squeaky rolling noise
    So, I've been driving my car for the past 3 months with a mild squeaky/rolling/squealling noise coming from my passenger side. I'm not sure if it's from my passenger side wheel hub, brake disk, brake pads, or transmission etc...? I changed my brake pads not too long ago, and brake disk is evenly flat...Any ideas, anyone have this problem? Could it be transmission bearing gone bad?
    could be wheel bearing.. jack up that one side of your car that you think is making the noise, and spin the wheel see if it makes noise. OR, hold the wheel firmly and shake it around and see if the wheel bearing is bad
    Yeah man. Fr33way's Avatar
    North OTP
    ^^^ First thought is wheel bearing seal drying out.
    It's all about JDM.
    CA to GA
    I'll try that this weekend, hey thanks...hope its the wheel bearing...
    It's all about JDM.
    CA to GA
    How do I check if the wheel bearing seal is drying out??? Would I have to take the whole freakin hub off from the axle and look behind it??? If so, then I do that this weeked as well...hey thanks fo the thought.
    Quote Originally Posted by Fr33way
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    check and see if you accidently bent the backing plate/dust sheild against the rotor. happens alot.
    It's all about JDM.
    CA to GA
    I forgot about that too....thanks for the input. I check this weekend as well.
    Quote Originally Posted by turbob20
