Results 1 to 4 of 4
Thread: Need 5 spd swap for f22
    Default Need 5 spd swap for f22
    i need the obvious, any f or h tranny in good condition
    ecu
    harness
    clutch pressure plate and flywheel
    shifter and shift cables
    brake and clutch pedal
    master cylinder
    and slave cylinder unless its already hooked to tranny
    pm me or call is good too
    678-763-4899
    thanks corey
    used or new hit me wit what you got
    check s&w or honda parts connection
    About to approach beast mode
    I have a clutch and lw flywheel. Prob have flywheel bolts an pp bolts also
    buford,ga
    i have some shifter cables that should work.
    94 si h23a1
    GPC member #2
