Results 1 to 23 of 23
Thread: Car over heating... !!!
    Default Car over heating... !!!
    Okay just finished a project, and cranked her up! but motor is over heating. and i was wondering why my fans dont turn on? but my gauge temp goes to like about a almost 60% and i shut it off. thats after like 20-25 mins warming her up?
    what activates the fans to turn on and off?
    is there any easier way to find out if my fans are bad? It was working before.
    every plug etc. is plugged to it's place, only thing not plugged up is the vtec/knock sensor/ etc plugs only. what else is there check for?
    /Oo ___A___ oO\
    |=_/_______\_=|
    Columbus
    not 100% sure but maybe the thermostat...or a blown fuse. i replaced my thermostat and it fixed it
    my thermostat, is in working order. I mean if it was not working it wouldn't read on the gauge, but only thing i'm looking it over is why doesn't my FAn turn ON. what activates the fan the turn on/off?
    /Oo ___A___ oO\
    |=_/_______\_=|
    Shinobi
    lawrenceville
    the fan relay it is in the junction box under the hood wen u open it up it s one of the big blackk fuses they r like 30 apiece at autozone
    Shinobi
    lawrenceville
    my **** was doing that same thing wen i first bought my integra and i changed the radiator the thermostat and my fans still didnt come on they told me it was that wen i put the new one in it came on right in front of me so i was good
    so most likely it's a FUSE then?
    /Oo ___A___ oO\
    |=_/_______\_=|
    turbos
    fan switch
    TOO BIG
    Quote Originally Posted by seanrg1116
    fan switch
    alright i'ma have to check it out then.. thanks..
    /Oo ___A___ oO\
    |=_/_______\_=|
    IA Member boosted91rex's Avatar
    Athens,Tn Hickory,Nc
    fan switch
    x2
    hmm thats the plug that connects on the side of the radiator coolant hosing right?
    /Oo ___A___ oO\
    |=_/_______\_=|
    General Tech Hater
    Quote Originally Posted by YouKnowIt
    so if your thermostat didnt work the gauge temperature wouldnt register on the gauge?? bwahahahahaha.
    Southside of The Jungle
    Quote Originally Posted by MidLifeCrisis
    He seems to not know much.If your thermostat doesnt work then it wont function properly.And you wont get the correct amount of coolant.My car used to overheat like that until I replaced thermostat.
    Greene/Athens
    already said..
    Out in the Boonies
    Check ur thermostat again V ... or better yet give my bro a call
    s1000
    clayton county/cobb county
    get your hands on a power probe and start testing.
    better to test, then to start randomly buying parts
    Senior Member 4DrTeg's Avatar
    just kall jim
    Augusta Ga
    its a long shot but if your fans dont come on , check the switch as already stated . if that doesnt work , try a different ECU . ive had a p28 ecu that had this problem and after i replaced it the fans came on ... then again its a suggestion . but i had this problem .
    93 sol Si
    95 sol S
    95 sol Si
    okay, ................... STILL OVER HEATING WTF...
    and one thing for sure is that i left it run for a a lil un 1hr and when it about reaches operating temp. the fan switches on and i'm getting alot of bubbles it gets to the point where it overflows the radiator, .. what do ya think?
    i had a suggestion from a member, that i should take out my thermostat and run it for a while.. and see if it's closing/opening iono.. ne1 done this b4..
    /Oo ___A___ oO\
    |=_/_______\_=|
    comme on...
    /Oo ___A___ oO\
    |=_/_______\_=|
    step sticky stephen's Avatar
    i'm assuming you did some sort of motor swap, right? make sure you don't have any air in cooling system. take the radiator cap off FIRST, then start the car, turn the heat on full blast, and just let the car idle until you don't see those bubbles anymore. the water in the radiator should have a more "flowing" look to it, not bubbling and gurgling.
    also, if you take the thermostat out it won't hurt anything. if you take it out, and the car runs cooler, then your thermostat was probably stuck closed. you can also test it by boiling some water, and dropping it in, and seeing if it moves.
    Quote Originally Posted by stephen
    thanks .. and i just saw it last night that this was posted in teh wrong forum, so i started another on in the right forum.. mods delete this one.. i have one started in general tech now thanks
    /Oo ___A___ oO\
    |=_/_______\_=|
    murdahrin dem Blood-Claat!
    take out the thermostat and see if it still runs hot.
    Quote Originally Posted by Ludester
    i havent got a chance to do so yet.. but i will try it.
    /Oo ___A___ oO\
    |=_/_______\_=|
