Results 1 to 19 of 19
Thread: Working on an idea - SR20DET "cost"
    Fake Suburban Environment
    Default Working on an idea - SR20DET "cost"
    What is the cost of a running engine and 5sp, would like the harness and engine computer as well so I can make it just 'run'.
    Got some devious plans...
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    Ghost AirMax95's Avatar
    On a Plane
    HP, WTF are you doing?
    Why would I tell you?
    Something faster than my M3
    1997 M3/4/5
    2004 X4 4.4i
    On a Plane
    Anything is faster than that Motorsport 3.
    ...goes to the Huffy 16spd w/ the trick chain links....
    Um no one on this forum knows anything about this?
    Geesh.
    1997 M3/4/5
    2004 X4 4.4i
    IA's Instigator
    Statesboro
    $2200... give or take
    youll have to change out your oil pan (might as well go with a nice ass greddy), probably want to change out the turbo, front mount, tune, mounts... will run you $3100 in the end.
    holler at killswitch performance though, theyre that fire... like the best drugs in town, theyre the best in the USA with sr's kekeke
    Oil pan may have to be reworked custom. Have a picture from the side of the profile of the pan?
    It is not your standard 'sr swap'
    1997 M3/4/5
    2004 X4 4.4i
    IA's Instigator
    Statesboro
    one of the only pictures of my sr i had.
    Can't find side pic.
    Need to see it from the side.
    1997 M3/4/5
    2004 X4 4.4i
    If its in your beemer, we just finished one LOL!!
    Motorsets are around 2k+ for a good motor,trans,ecu.wiringharness.
    IA's Instigator
    Statesboro
    ill find one man. one sec
    IA's Instigator
    Statesboro
    N/a but same size block if i remember right
    IA's Instigator
    Statesboro
    Something like that.
    What body style?
    2K ish is not bad at all.
    1997 M3/4/5
    2004 X4 4.4i
    20 side of thangs
    2500+ bux for a motrset with ecu and uncut harness.
    .46 secs of google told me that
    http://www.jkmsports.com/sr20det.php
    Augusta, GA
    JHOT has one on it's inventory list for $1925. It's a blacktop, too.
    Bender A. Rodriguez
    Macon
    Don't worry, its about the same size as an S14. From what I've seen it even sits in roughly the same location, only leans to the other side. I'm gathering my info on putting one of the SR's I have into my E30 in the spring. Now that I work with 3D modeling and CNC machines designing some mounts and cutting them will be pretty easy. There's a couple of guys on E30tech and bimmerforums who have them in E30's and I beleive I found an E28 with one as well.
    Ryan Reynolds
    Mr. JDM
    Atlanta GA
    depends the motorset about 2K
    upgrades depends on what kinda power you are thinking
    1st thing is greddy rocker arm stoppers which are about 75-100 dollars depends where you go. they will save your head from having to be remanufactured when you get the high revs. I have help build several Sr20's so please IM me with your plans and i can stear you in the right direction to go for the parts and what you would need.
    img]http://www.nicoclub.com/banners/Z1.gif[/img]
    http://www.z1motorsports.com
    2877 Carrollton - Villa Rica Hwy
    Carrollton, GA 30116
    770-832-7457
    [email protected]
    AIM:seanbz1
    MCD
    you motor set..2000, ras 75-100,gt2871r 700-1200 (assuming you keep it bottom mount and stock t2 flange),greddy cams 200-400,cometic head gasket 150, arp head studs 150, and you can do atleast 350 to the wheels safely. prob stay around 18psi. those are good numbers
