Results 1 to 17 of 17
Thread: TiAL BOV compression surge
    FLOSSIN' MR.EM1's Avatar
    Default TiAL BOV compression surge
    my tial bov doesnt open all the way to release the pressure, maybe a quarter of the way but when it does its takes forever for the slide in the bov to close. Is my bov going bad or can i take it apart and lube up the inside of the bov? REPs for help.
    FL
    Because I eat RICE RiceBoy's Avatar
    How much pressure are you running on the BOV? Maybe you should reduce the spring inside? If you dont' know the pressure, you can either get the serial number off the BOV and email Tial or take it apart and check out the color of the spring.
    02 WRX patrick4588's Avatar
    warner robins
    try swapping the spring, you may have the wrong one installed. diaphragm bov's ftl. lol
    GCO Member
    NRA Member
    im at 8 psi...dunno bout pressure to bov
    FL
    warner robins
    where are you getting your vacuum source for the bov?
    GCO Member
    NRA Member
    Northwest Georgia
    i have the same issue, i just haven't cared to fix it, since it was brand new, i think it releases enough air not to matter really. Lowering the spring rate costs about 40$ for another spring. My new cams draw less vacuum now so im considering getting the weaker spring now.
    yea mine is fairly new dunno how it will affect other things.
    my vaccum source is coming from my golden eagle vaccum box
    FL
    warner robins
    i wonder if you could just cut the spring a little bit? like half a coil or something
    GCO Member
    NRA Member
    00 EK B18B1 boostedy8's Avatar
    Gainesville
    I had the same issue as well. I CORRECTLY matched the spring rate for how much vacuum my engine produced at idle. Tial has a chart that you can go by. Put the new spring in and it works like a champ. I would try that.
    jupiter
    Quote Originally Posted by boostedy8
    I had the same issue as well. I CORRECTLY matched the spring rate for how much vacuum my engine produced at idle. Tail has a chart that you can go by. Put the new spring in and it works like a champ. I would try that.
    -REPs
    Flowery Branch
    trash it and buy my Synapse engineering one, new in box, i'll refund you your money and you can keep it if it does not completely eliminate the problem!
    100$ paid double that on egay...i'll be at the meet thurs as well.
    warner robins
    nice price!
    GCO Member
    NRA Member
    Nothing wrong with the Tial, its a very nice piece. At least he didnt go buy Turblownetics garbage.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    who the hell is TAIL?????? i never heard of them before pls explain.
    FL
    Gainesville
    Quote Originally Posted by MR.EM1
    What are you talking about? Neg reps for you!!! Lol J/K
    who r u??? u dont even have a boosted car
    FL
    jupiter
    who posted on my account?? lol i havent even seen this thread yet????? ben???? WTF hahahahhahahha
