Results 1 to 21 of 21
Thread: Heated Floors? WTF!
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Default Heated Floors? WTF!
    I'm having an issue with heat coming from my floorboard underneath the stereo/shifter area. It's making my feet really hot and I'm sick of it! I've noticed that the floor vent never goes all the way off, but it's not blowing hot air. There is definitely heat radiating from the floorboard. All I can come up with is that it must be coming from my exhaust somehow. The engine is not overheating and the heat shield near the shifter under the car is in place. Anyone have any ideas on what could be causing my problem and what to do about it?
    EE OG Revmaynard's Avatar
    I thought you meant like bathrooms. I was gonna post about my dads bathroom with heated floors. But nvm. And I have no clue as to the initial post. Sorry. LOL
    Bozzio for president.
    Locust Grove
    LOL nah, I wouldn't be posting that in general tech
    Never go full retard
    Nashville
    Has it always been a problem? I have a friend that drives a Blazer and heat has always radiated from the engine bay/under the car into the feet area.
    Do you have an aftermarket exhaust or something that doesn't have a heat shield/wrap?
    Locust Grove
    Yes, I have a 4-2-1 Greddy Stainless header with a magnaflow high flow cat that I installed a few months ago and whatever cat-back system the car had on it when I bought it. I don't know if it's always been a problem because I haven't had the car that long. You think some of that heat wrap from the parts store around the header and possibly the cat may help? If I'm not mistaken, I do believe the area I'm feeling the heat at is about where the cat sits. The car does have a heat shield there, though.
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    My civic was doing that. After I had it Converted from auto to manual(An extra opening was cut and never used). Try riding with the windows up for a minute, and see if it stays at a normal temp. Then crack window/roof and see if it heats up the floor. If so you definately have a open in your floor board. Shiit you might could just get the car on a lift somehow and find it that way. The only way I fixed it was to just weld it shut.
    Locust Grove
    Thanks, I'll have to check into that. Might be able to get a rubber plug like the ones you find in the firewall if this is the case though, you think?
    Ball till I fall. BallerDave04's Avatar
    Macon, GA
    You might wanna wait to fix the problem until after winter LOL! It's right around the corner.
    Nothin yet...
    s2k pusha
    Athens, GA
    your cat could be clogged and heating up, ive seen cats so clogged they were turning red, put it on a lift and look at the cat and try to see how much heat is coming from it, but then it again is a high flow cat, those don't usually go bad that often, but it is possible
    Locust Grove
    Quote Originally Posted by trc_gsr
    If it were going bad, I'm sure I'd be throwing codes by now.
    Quote Originally Posted by BallerDave04
    LOL, yeah I thought about winter just being around the corner!
    Senior Member 9ussy's Avatar
    same thing happens to me also.. so i don't know whats wrong.. i have a test pipe or straight pipe whatever so i don't know if that would be causing the problem??
    Senior Member 1CleanEg's Avatar
    man i have the same problem. I have a 95 integra ls and it gets pretty annoying. I have no aftermarket parts at all and it happens.
    __________________
    1993 Honda Civic - stolen
    2001 Honda Accord - sold
    1995 Acura Integra - sold
    2003 Audi A4 - current
    Locust Grove
    I talked to my father, who drives a '92 DB1 and he said he also has this problem. Must just be the nature of the beast. There's gotta be something you can do about that, though!
    Quote Originally Posted by psycho_freke
    Yea. Get a fan like the overweight school bus driver that drove you to school and aim it at your feet.
    Garage-Sixgun
    Stang Mod slostang's Avatar
    Southside
    I think all Honda (idk if this is what we are talkin about) always heatsoak. I know mine does. lol
    1010011010 Atlblkz06's Avatar
    Hell
    "Heat soak" has to do with the engine block/intercooler and other parts of the engine heating up from residual heat. Don't just throw out terminology like that.
    I have this problem in my car and my car is freakin bone stock. The only way is to wrap the exhaust, add extra shielding, or insulation under the carpets in the floorboard area. Eventually I'm going to do all 3.
    IA Member jtaylor48's Avatar
    Exhaust wrap is known to cause rust problems especially in undercar applications. Just throwing that out there
    Gas is too expensive to drive hard and my insurance can't take anymore fast.
    ALL CAPS JITB's Avatar
    Quote Originally Posted by jtaylor48
    i never had that problem with exh wrap.. and i had it for 3 years.
    Its prob the heatshield that is probrably gone. From the aftermarket exhaust. Or you could really have a hole in the firewall form the auto-manual conversion... my shifter heats up after long drives.. b/c of the lack of heatshield form the aftermarket exhaust.
    Locust Grove
    Not sure which heat shield you're talking about. I do know that there is a heat shield under there near around the same area that keeps heating up. Not only is it not coming from the firewall, but there was no auto-manual conversion. The GSR only comes in manual. Aftermarket exhaust is the only one of these three possibilities you're giving me that may be a possibility.
    whoops i was reading twinJ's comment and i thought u did the conversion.
    But there is a heatshield (or should be) on Oem exhaust, like above the Cat, and or under the shifter linkage, to keep heat from coming in thru the floor like that. and to protect the bushings in the shhifter linkage.
    Locust Grove
    Yeah, I've still got that.
