Results 1 to 10 of 10
Thread: 4000 hp integra more info & pics at www.turbomagazine.com
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    Default 4000 hp integra more info & pics at www.turbomagazine.com
    CLICK ON Xs FOR PIC
    Try, for a moment, to comprehend a four-cylinder engine capable of achieving 4,000 hp at 55 psi turbo boost on nitromethane. It gets wild pretty fast. A single horsepower is defined as the ability to lift 550 lbs one foot in one second. Bob Norwood's 4,000-hp Turbo-Fuel Max-4 powerplant can lift 2.2 million lbs--1,100 tons--a foot in one second. This is about the weight of a 50-car freight train, but then again, the Max-4 has as much power as a railway locomotive. Another way to look at 4,000 hp is that the Max-4 is capable of lifting one ton straight upward 1,100 feet in a single second. Try to comprehend an engine in which every power pulse--each putt--can lift 4.4 tons upward one foot in one second. This is the type of mayhem a 4.8-liter inline four is capable of when you force-feed it air at a rate of 200 lbs per minute and pump it full of nitromethane at a rate faster than you could dump it out of a bucket. No matter how you quantify it, this is the extreme edge of high-tech performance.
    The Norwood Type R Funnycar body tilts up to reveal the twin-turbo/Fuel Max-4 engine. Lowering the body automatically connects cold air-intake plumbing to both turbochargers
    With the Max-4 Turbo-Fuel Type R Funnycar, Dallas supercar builder Bob Norwood once again exhibits his well-known penchant for bringing a sledgehammer to a fly-swatting contest. The Type R drag car and Max-4 powerplant are designed to deliver 250 mph and 5.50-second quarter-mile performance on alcohol and nitromethane. The vehicle is designed around a narrowed Mark Williams tube-frame chassis with a narrowed one-piece composite "Integra Type R" body. At 286 cubic inches, the engine is clearly the largest non-aviation four-banger ever constructed in modern times.
    The Type R's Max-4 engine is conceptually half of an Arias 500 cid Top-Fuel drag-racing V8, topped with an exotic triple-plug, four-valve-per-cylinder DOHC Batten Performance cylinder head. The engine is based on an immensely-strong aluminum block milled from solid billet without cooling passages--a mighty, solid-block dual-fuel powerplant designed to achieve 3,000 hp on 55 psi of twin-turbo boost, using nitromethane delivered in bulk via constant mechanical injection and trimmed with gigantic port electronic injectors.
    The Acura is powered by super hybrid four-cylinder engine featuring a custom billet block with a 4.5x4.5 bore and stroke and an outrageous Batten four-valve triple plug head. The Nitro burning beast is expected to generate 1,000 hp per cylinder. Whoooaa!
    Norwood Type R Origins & Concept
    Our Type R project grew out of the goal of building an import-style (turbo four-cylinder) nitro Fuel motor that did not self-destruct on a regular basis," says Norwood.
    We decided our powerplant should be a dry-airflow motor, with Fuel introduced to the intake tract less than 3-inches from the intake valve.
    9/16 Donovan TFX ("Top Fuel Experimental") studs help hold the TFX billet main caps in place. Each cap is also retained with two side-bolts fastened through bosses on the side of the block.
    Close up of the Max-4 block reveals machining to provide rod clearance on each side of the cylinder.
    "Running turbochargers," says Norwood. "Introduces the problem of having enough boost to launch effectively at the starting line. But over the past few years, we have very successfully used nitrous injection to 'spank' up turbos so that they spool almost instantly. Nitrous works great with gasoline, and it works even better with nitro. Without tons of boost and load, nitromethane can be a dead fuel, but nitrous oxide is a very fast oxidizer.
    Bob Norwood lowers the Rody billet crank in to the Max-4 and turns it in preparation for fastening the main caps down with both studs and bolts.
    Max-4's Childs and Albert Hemi-style aluminum rod next to a competition Honda 2.2 rod and a SOHC 1.6 rod
    Block
    As if anticipating the gestation of the Norwood Max-4, recent NHRA rules established new Pro classes for "Import Performance" eight, six and four-cylinder engines, all of which must use overhead camshaft designs. Pro Class V8-powered cars must weigh 2,350 lbs, use a production (cast) block, and utilize overhead cams. By contrast, four-cylinder vehicles need only weigh 1,750 lbs, and may utilize custom billet cylinder blocks.
    Max-4 piston, rod, wrist pin, and rod cap. No pin-retainer is considered reliable enough in a Top Fuel environment; the full-floating wrist-pins are retained with aluminum spacers held in place by the cylinder walls themselves!
    Norwood Autocraft teamed up with Batten Performance and C&N Blocks to develop and manufacture the first batch of six Max-4 drag-racing blocks from heat-treated billet aluminum. Each block, carved from aluminum billet using five-axis CNC-milling equipment, was designed to weigh in below 100 lbs. Each Max-4 block is manufactured without cooling or oil drain-back passages from a $1,650 chunk of solid billet aluminum to big-block (7.4-liter) Chevrolet bore-center specifications. The Max-4 short block is designed for compatibility with a special 112 cc Norwood version of the Arias-type Batten Performance B4 cylinder head, and merges Batten, Norwood and C&N Blocks concepts.
    Inserting the main-cap cross-bolts into the Max-4. Next generation Max-4 will have four-fastener front and rear caps in addition to the current four-bolt center mains.
    Following the initial milling operations, each Max-4 block is blue-printed to the highest standards of precision machining for installation of radically strong Darton 4.5-inch-bore steel cylinder sleeves and a 4.5-inch stroke Rody ("row-die") crankshaft. The crank is supported by four-fastener, cross-bolted Donovan Top-Fuel-Experimental (TFX) center main caps. Norwood designed the main and rod journals to utilize Top Fuel Chrysler Hemi-type bearings, aluminum rods and main caps. Each Donovan center main cap is secured with two main studs and two cross-bolts.
    Max-4 short block, ready for Batten B-4 Twin Cam 16-valve head installation. (Note Type R Funnycar's cowl to the right).
    Crank & Reciprocating Assembly
    The Norwood Max-4 engine has a static compression ratio of 12:1 when fitted with JE flat-top forged "Top Fuel" pistons and standard B4 95cc combustion chambers. However, when fitted with larger 112cc chambers, dished pistons and shortened rods, the Max-4 has the ideal 7:1 compression ratio required for high-boost nitromethane drag racing.
    Each Max-4 piston is equipped with a 0.017-inch L-shaped Dyks moly-coated top ring for both reduced weight and a wide cylinder contact surface. Each piston is fitted with a 1/16-inch Z-gap ductile-iron second ring and a conventional three-piece oil-control ring. Each piston is fitted with a full-floating Top-Fuel Childs and Albert Hemi aluminum connecting rod with cold-cycle cryogenic-treatment.
    Each 9/16 x 11-inch Donovan TFX head stud received 130 lb/ft of torque.
    Although Top Fuel V8 systems support the lower main bearings with a supplemental oiling system pressurized with a 3,000 psi CO2 tank, the Max-4's crank and bearings need only handle half the power with the same number of main caps. Therefore, a three-stage dry-sump oiling system provides 100 psi of lubrication to the Max-4, pumping fresh synthetic motor oil to the engine and turbos from a dry-sump tank vented through the frame of the vehicle. The dry-sump system directly scavenges oil and crankcase gases from all four corners of the cylinder head, the sump and both turbochargers.
    Here we see the cam and follower atop the front valve and triple springs. We're talking 550 psi open valve spring pressure.
    Cylinder Head
    The Max-4 is equipped with a modified Batten Performance B-4 drag race cylinder head of the type designed to fit Arias Big-Block Chevy Rat-type blocks. This drag-race head is solid (without water-jacket cooling passages) and can only be used for short-duration drag racing. Each football-shaped B-4 four-valve pentroof combustion chamber is equipped with triple spark plugs for igniting the unimaginably dense air-fuel mixtures at 55 psi of boost with air-nitro ratios in the 1.75:1 range--meaning 40-percent of the charge mixture is fuel, as opposed to the seven percent you'd typically see in a gasoline-fuel powerplant.
    Lowering and tightening the second cam box and studs on the Max-4.
    The B-4 is equipped with four immense oval intake ports (1.560-inch high by 3.630-inch wide), which divide just upstream of each set of twin intake valve throats. Each port is capable of flowing 620 cfm at .550 lift. The intake ports direct charge mixtures almost directly into the combustion chambers with both swirl and tumble.
    The included interior valve angles are 24-degrees intake, 26-degrees exhaust. The intake valves are 1.750 inches, the exhausts 1.500 inches. Eventually, Norwood plans to run coolant through the Max-4 head, though never in the head gasket area, thus maintaining a dry deck under all circumstances. Should the head ever "dance" up and down under the unimaginable combustion forces and pressures of 4,000 hp, it's--and will always be--impossible to get coolant in the oil.
    Max-4 engine with cams and sprockets secured to the Batten B-4 head. Each camshaft provides a direct drive for a high-pressure in-line mechanical fuel pump, one a Waterman Red "Little Bertha" 40 gal/min nitro pump, the other an Enderle eight gal/min pump for 80-percent ethanol, 20-percent VP-116 race gasoline. Gasoline improves the startability of Ethanol. The concept is to avoid fires and mechanical damage by keeping harsh nitromethane out of the oil as long as possible.
    Camshafts & Drive System
    The Max-4 is equipped with camshafts made from Norwood custom 8420 billet blanks that are copper-plated and hardened. Cam Motions roughs, hard-faces and grinds the cam to Turbo-Fuel specs of 265-degrees intake timing at .050 and 255-degrees on the exhaust side. Both cams are driven directly from the crankshaft with a single toothed 1.5-inch belt.
    Intake Manifold
    The Max-4 intake manifold consists of 5-inch straight tube primary runners, which blend from 3.5-inch ovals at the head end to round at the plenum end. The plenum is a 20-inch long round tube and tapers evenly from 5.5 to 4.5 inches. A 3.5-inch throttle body regulates intake air from a 3.5-inch feed pipe from twin turbochargers.
    Max-4 Fuel System
    Two gigantic Turbonetics Q-Trim ball-bearing turbos stand by to ingest burning nitrous exhaust hell and spit out the 55-65 psi boost required to unleash 4,000 hp for 5.5-second, 250-mph blasts down the quarter mile.
    The Max-4's bulk fuel delivery system is organized in a way analogous to that of a Top-Fuel V8 Funny Car: The Max-4 system is based on a conventional constant-flow high-pressure nitro fuel system. Fuel pressure and flow is limited by the variable percentage of barrel-slits uncovered by the barrel in a nitro fuel barrel valve. Twin Down-Nozzles per cylinder--located in the head intake runners--provide the bulk of the nitromethane consumed during each 5-second, 250-mph drag run. Four huge electronic injectors located in the Max-4 intake manifold function analogously to the eight "Hat Nozzles" located on the plenum of a Top-Fuel V8 atop the supercharger just behind the gigantic throttle butterflies to provide the essential "wetness" required to lubricate the lobes of the Root-type blower and provide the fuel for idling. In the case of the Max-4, there's no need for fuel lubrication; the electronic "Hat Nozzles" provide additional computer-controlled fuel "trim" required to optimize the air-nitro mixture for maximum power and engine life, and to supply optimal amounts of nitro fuel for idle just prior to launch.
    The downside of a Top-Fuel V8-type fuel delivery system is that these systems effectively provide for idle or wide-open throttle--and nothing in between. Starting, idling, burning out and then launching a 6,000-horse Top Fuel engine on nitro turns the oil into explosive "slop" that can be extremely dangerous, and is the most common reason for fires in a nitro-burning engine. Which is why the Max-4 starts, idles, burns out and backs up on E-80 ethanol (80-percent ethanol alcohol, 20 percent leaded VP-116 race gasoline), not nitro. It's only during the final idle just prior to launch that the driver switches over to nitro (or a specified combination of nitro-alcohol fueling). Essential to the key Norwood strategy of providing a solution for cost-effective ultra-high-output boosted-Fuel glamour-class "Import" drag racing by greatly reducing engine failures is a second set of high-flow electronic injectors designed to deliver E-80 ethanol under the control of an independent auxiliary M48 Motec engine management fully knowledgeable of the current status of the nitro delivery system. A Motec M8 calibrates the nitro-side electronic injectors and handles data acquisition. An electric Walbro inline fuel pump provides fuel for starting.
    The Max-4's launch is fortified with port nitrous oxide/fuel injection, which provides a sudden scorching blast of power and heat that explodes the vehicle off the line and nearly instantly accelerates the giant twin turbochargers to full boost. It turns out high effective compression ratios in the combustion chamber are essential to efficiently and effectively producing prodigious amounts of power in a nitro motor (see sidebar); squeezing the required 1.75:1 air-fuel ratio hard in the combustion chamber is vital. Bottom line, combining nitrous injection with turbocharged nitromethane is a devastatingly effective recipe that unleashes the nitrogen-bonded hell of nitromethane's potential energy--in a hurry. The Max-4's E-80 ethanol fuel supply system makes use of an 8 gallon per minute Enderly in-line mechanical fuel pump driven directly off the exhaust camshaft. The pump, electronic injectors and pressure regulator, says Norwood, are capable of fueling more than 1,500 hp on E80. The alcohol system normally runs continuously, with the nitro system designed to come alive when it's time to go Postal. The intake cam directly drives a Waterman Red "Little Bertha" mechanical fuel pump driven to provide up to 40 gallons per minute of nitromethane to the staged-nitro system consisting of four electronic and eight constant-flow mechanical injectors. Depending on the jetting, the nitro delivery system can provide fuel for up to 4,500 hp. The Max-4 can go down the track on straight alcohol, straight nitro, or anything in between.
    Force-Feeding The Max-4
    The initial Max-4 turbo system employs twin Turbonetics turbochargers, which are coated by Norwood Autocraft. The turbos units have special giant compressor wheels able to move the extreme quantities of air required for more than 3,000 hp at 55-60 psi boost. These turbos have ceramic ball bearings and are coated to take the heat. Norwood also plans to test the Max-4 pressurized with a single gigantic Schwitzer turbocharger fitted with a 111mm Holset compressor wheel and housing components originally designed for large truck and railway locomotives.
    Senior Member jfman's Avatar
    STILL HERE!! tron's Avatar
    loganville
    ^ lol...but yea that **** is wild!!! just think.....a street version would domminate! but idk if its possible....but its good to dream!
    -car and driver, 370z review
    turbos
    TOO BIG
    loganville
    just click the damn x to see pics
    JDM TYTE AnthonyF's Avatar
    4000hp on the street isnt possible. You do know this car probably gets rebuilt after every run. lol.
    The Carbon Fibered R6
    Zoom Zoom kfzemx3's Avatar
    atlanta
    I spend money on HP not Brand Names.
    08 Infiniti G37s 6MT [The Daily Beast]
    05 Mitsubishi Lancer Evo VIII MR [Sold]
    01 Lexus Is300 [Under Construction]
    93 mazda Mx-3 SE 2.5 Klze [Sold]
    92 mazda mx-3 GS 2.0 Kfze [I Killed it]
    IS EPICZ
    in dabuilding
    ugly as hell body but its the inside that counts just like many other things lol
    Daytona Beach
    http://www.turbomagazine.com/tech/02...gra/index.html
    Here is the link to the pics for this guys thread.
    Just like in the NHRA, this has nothing to do with an integra besides the mock bodywork.
