Thread: Built EJ6 $4,000
    IA Member JDMJorgie's Avatar
    Dalton, Ga
    Default Built EJ6 $4,000
    97 Honda Civic Dx
    Interior
    red carpet
    rockford fosgate crossovers
    Mugen pedals
    carbon fiber E-brake
    B&M short throw shifter
    Autometer Tach
    Exterior
    16 inch ICW rims
    Brembo cross drilled & slotted brakes
    Axxis Carbon Kevlar brake pads
    Coilover suspension
    Full Header Back 2.25 in Exhaust w/ Cherry Bomb
    Spoon style mirrors
    Engine
    Built LS/VTEC motor (B18a1/B18c1)
    DC headers
    Blox intake manifold
    Hondata intake manifold gasket heat shield
    B16 throttle body
    Short ram intake
    H22a1 injectors
    Crower stage 2 "402" cams
    Supertech valve springs
    Supertech valve spring retainers
    Ferrea valves
    B16a pistons and rods running 11-5-1 compression
    Tranny
    B18c1 tranny
    Comp stage 4 six puck clutch
    Lightened flywheel
    Royal Purple Tranny fluid
    The car is using a P72 ECU that's been tuned by Mainstream Performance. It has had roughly five hours worth of tuning and dyno time . There is very little else that can be tuned. The car itself runs great, when VTEC kicks in it sounds totally differant and the front of the car literally lifts up when it kicks in at around 5500 rpm. When dynoed it put down 189 HP with 158 LBS of torque. With a little bit more parts it can easily hit over 200 HP.
    The main problem with the car is of course the motor mounts. It'll jump around when you try to move forward and reverse but it's an easy fix. The car broke down on me about two months ago and found out it was a distributor cap and rotor button. I fixed it but I advise you get a new one. Besides that, the only problems are that it needs a couple of tires. I just can't put any more money into it. Also the valve cover needs to be RTV'ed again I missed the front left corner and it leaks a little bit of oil. With a little bit more money put into it, it can be a great contender and daily driver.
    Let me know if you need any parts I can get you anything you need.
    PM me if you are interested. Thank you.
    Attached Thumbnails Attached Thumbnails -s2010951-jpg   -s2010954-jpg   -s2010956-jpg   -s2010963-jpg   -s2010959-jpg
    a.k.a. s14slider
    in your closet
    and I don't think you meet the requirements to post up. Sorry
    I don't need a sig. Oh wait, damn it.
    Indecisive SOB aguynamedpat's Avatar
    In your attic
    Yes he does, he joined before April of 08, so he is grandfathered in.
    Dalton, Ga
    I have tried to post this car on here for awhile and it wouldn't let me, then I tried again today and it let me do it. So here it is. If there is any problems I'll pay the 10 dollars need for noobs to post cars for sale, but I don't think I should.
    any trades?!
    Dalton, Ga
    What kind?
    well i got a supra to offer i dont know about him
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
