Results 1 to 3 of 3
Thread: Need info on Bseries ring gears, Dseries guys theres interesting stuff in here foryou
    140 on one wheel
    columbus, ga
    Default Need info on Bseries ring gears, Dseries guys theres interesting stuff in here foryou
    http://www.honda-tech.com/zerothread?id=2276278
    To start of with i was reading up on another individuals thread off of H-T. Well i have been planing on being one of the few in the US with this tranny im attemting to use which will include a 86-89 CG integra tranny mated to my d16z6 block. D-series trannys are known for sucky gear ratios, and known to break or go out pretty quickly after reaching power levels of 400+. The purpose of the hybrid tranny is the transmission is essentially like a tougher b-series transmission that bolts up to sohc d-series blocks. And on the 86-89 CG integra, 5th gear is on the outside of the case. kinda like how people replace 5th gear with a handcuff, well this one has a handcuff built into the trans and you dont have to get rid of 5th gear. The gear ratios are much shorter than the z6/y8 trans....more comparable to a GSR tranny. Now to get to the point....Ive already aquired everything for the conversion but my LSD. I understand that he is using a B16 OBX lsd and everything droped right in. My question is i picked up a b16 KAAZ Lsd off H-T with a LS ring gear and i need to know if they are the same or if i will need a b16 ring gear before i drop it in my tranny.
    Thanks!
    140 on one wheel
    columbus, ga
    guess im about then only one who knows about tranny internals or how to tear apart and rebuild one
    b16 and ls diffs are different sizes so if the kaaz has a ls ring gear then a b16 gear wont fit.
