Results 1 to 40 of 61
Thread: $150 paint job.(Lots of pics)
    Thumbs up $150 paint job.(Lots of pics)
    Edit:close up shots on bottom now-
    DIY now up-please comment anything left out and ill adjust!
    http://www.importatlanta.com/forums/...9#post37124219
    Goal was to do it myself,and cheap. Got new doors so I didnt want to ride around with diff color doors.
    quart of Shopline paint-$78
    Gallon of Smart clear with medium activator-$66
    Husky disposible drop cloth $1.99
    -All ready had sandpaper,tape and other misc items from previous projects-
    Its not perfect but im happy with it.
    started off with this rotting orange peel effect car;
    Then hours of sanding and buffing due to my painting mistaks
    -No wax,just compound and polishing swirl remover-
    close ups as requested:
    can see the 'pin holes' in some areas i didnt get all the way out.but gotta get close up to see.
    Banned ILOVEKIDDRACING's Avatar
    Palmetto, GA
    Well... for 150 not bad...
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    i ain't gonna lie, thats pretty darn impressive dude.
    Paintwork looks really good, the wetsand stage is critical for home paint jobs.. nice work
    Dunwoody
    damn dude that aint bad at all for $150
    Flush TSX JDMEK18's Avatar
    Gets my vote!!
    appreciate it guys..just a bored result of no job and school not started yet..ha
    is ARMY STRONG!! b16EG-HaTcH's Avatar
    Ft. Bragg
    damn nice job. reps for a diy'er
    hell yeah man, thats not bad at all for 150. any close ups of the paint? its not as orange pealed as that one pic right?
    I CAN HAZ 8 CYLINDERS?
    Cameron Flaisch Photography
    Canon Shooter
    turbos
    wow good job. Do u want to paint a hatch?
    TOO BIG
    uploading now.
    no no orange peel..its slick as glass now..i have a few like pin hole type things in few areas i didnt sand all the way out.but you have to get up close to it..ill see if the pics can pick them up.
    Sep 2003
    What type of gun did you use to spray it with?
    i used a Sharp SGF-HVLP-55 (1.4mm tip)
    Canton, GA
    Could you by chance post where you bought the paint/supplys, what prep work you did (with what tool equipment/grit paper), what type gun/spray can you used(where you got it), and exactly how you wet sanded/polished the panels to get all the orange peel out.....thats DAMN impressive. I've been looking into painting my own car for quite some time now.....its would be awesome to have similiar results
    Canton, GA
    Quote Originally Posted by 1NonlyAccord
    is that electric or airpowered?
    i need ae86 parts canadianrcis's Avatar
    marietta
    damn,thats sick for the price. cant beat that.
    hachi roku groove
    ATL, GA
    very nice!!!
    That's some of the worse orange peel I've seen...you've really fixed it up. Well done!
    Canton, GA
    worst
    and i've seen worse
    1010011010 Atlblkz06's Avatar
    Hell
    If you could post a detailed DIY, I'm sure TONS of people could use it.
    GREAT JOB! - It looks amazing for something you did at home. Never thought a home paint job would turn out so good.
    Canton, GA
    this thread needs tons more pics and info and a step by step write up, then stickied and archived
    Quote Originally Posted by Sport1.3
    I got the paint mixed up from a place in Glenwood. Got the Clear coat kit from Autocolor(finish masters) in Lawrencville-Hurricane shoals rd, im sure they mix up paint there also.
    I went to Harbor freight and got;
    Masking paper-to tape windows,practice spray patters ect,
    5pc Disposible paint cups for the gun,
    adjustable air reg with gauge
    disposible inline water traps
    I already had the gun,tape,and all the sandpaper and stuff
    10Gal. 2.5hp Brute air compressor, 50ft 3/8th air line
    grits from 400-3000 (800-3000 is WETORDRY)
    400/800 dry is for sanding the car before paint.(using a 6" DA-Air powered)
    clean the surface with prep wipes,or wax grease remover, then Tack cloth.
    tape off everything get everthing ready to spray and go at it. waiting 10/15 mins in between coats to flash the solvents(read paint specifications for that and mixing rations ect)
    then to get orange peel out(if done correctly then it wont be as bad as mine that was the result of gun not set right)
    but depending on how bad it is, start off with 1500grit wet and a paint stick and start blocking by hand till its flat,no trash...then go over it again with either 2000g and if applicaible 3000g( i had access to that since i worked at a shop and took some before i quit..ha)
    then use a rotary buffer with 3m white-Compound pad, 3m Gray-Polishing pad( if black or darker colors 3m blue pad-waxing
    Say Somethin'
    in that one girl...
    damn that looks pretty good
    weak civic
    Quote Originally Posted by Atlblkz06
    i can make that..but i didnt take any pics of the sanding process..but its pretty much self explainatory..i can just right up the steps..
    ok so ill be making that as we speak..in the general tech spot im assuming?
    Cibai cartune's Avatar
    SoCal > Atl
    wana paint my car? lol
    homie dont play that
    looks very good for the price
    ....True ////OFFSET\\\\
    San antonio 210
    damn dude, that great job for the price. Not like some others on here *caugh caugh* Cgeven (sp)
    Certified Gearhead Silvrmaxx's Avatar
    G-nett
    damn dude, pretty impressive, especially for a DIY at home paint job.
    Shift_Clean
    appreciate it guys; im in the process of making a DIY..so give me some time if yall have questions..ill check back periodically
    Canton, GA
    damn sounds like i'm going to be needing an aircompressor afterall lol. off to craigslist !!!
    MOST HATED
    Upstate SC/ATL
    This is def quite impressive to say the least...Good job on your first paint job....Looks 1000 times better than the camo spraint painted Civic in another thread....
    Kennesaw, GA
    good job looks great
    Macon
    I'm impressed at what people can do with a little money and a buttload of talent and know-how.
    Reps.
    Ghost AirMax95's Avatar
    On a Plane
    Nice DIY job! I will pay you $350 to paint an E-class Benz for me. Seriously!
    PM me!
    the land of race car ya-yas.
    damn good job for a DIY project.... i know of a shop that needs a good painter or two....
    Cobb County
    DAMN!!! Good job man dude!
    DUDE GET AT ME! im looking for a job again!!!!!!!!! haha
    part time tho
    after 2 on mon and wed..but tues,thur and fri im full time-collage schedual
    LOL I dont think you wanna work where he is talking about
    Quote Originally Posted by dteng
    x2
    R A W! x Resilience's Avatar
    Atl
    Rockstar FTMFW.
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
