jdm b16a..this is what i have..need to know if i need adjustable cam gears for this build...gonna be 18-20 lbs. on pump gas
81.5mm bore
eagle block guard
9 to 1 je pistons
eagle rods
acl bearings
eagle crank
arp headstuds
oem water pump
oem oil pump
ctr cams
rocket retainers
rocket dual valve springs
skunk 2 intake mani.
70mm throttle body
benen fuel rail
RC 1000 cc injectors
3 bar map sensor
oem head gasket
hondata intake gasket
garrett t04e
tial 44mm v-band wastegate
obx stainless top mount mani.
3" down pipe
hallman pro boost cont.
apexi turbo timer
full hasport mounts
ls cable tranny
competition stage 5 sprung
oem axles
