Results 1 to 11 of 11
Thread: 427ci SBF Race Motor 600+hp NA 1000+hp on Nitrous
    In the Fucking A
    Default 427ci SBF Race Motor 600+hp NA 1000+hp on Nitrous
    This Motor has never even been fired
    World Products Block
    Eagle Crank
    Eagel Rods
    Mahle Pistons
    Total Seal Rings
    Clevite Bearings
    13.5 to 1 compression
    Ported AFR 225 Heads
    Upgraded Valves and Valve Springs
    Jesel Solid Roller Lifter
    Jesel Shaft Mount Rockers
    Danny Bee Belt Drive
    Bennett Nitrous Cam
    Trick Flow Box intake
    Accufab 90mm Throttle Body
    MSD distributer
    ATI Dampner
    Fuel Rails
    42lb injectors
    Water Neck
    Tilton Starter
    MSD Plug Wires
    Trick Flow Nitrous Plate
    Motor is setup for Fuel Injection I have a FAST setup that is available with it.
    I've got over 12,000 invested in just the motor. Ill listen to any reasonable offer. I might even consider a trade for a street car.
    Also available is a Viper T-56 with Mcleod bellhousing adapter and a Mcleod Twin Disk Clutch as well as a set of Kooks Headers. I also have a MSD 7AL2 and a MSD coil that can go with it.
    Motor is supposed to make in the 600hp range with no spray and was setup to make over 1000whp.
    These are all brand new parts this motor has never been fired. I would love to keep it but I need the money to start a new business venture and building another car just because I have the motor is not a good idea.
    $10,000 obo
    Matt
    I fucked İhris's mom
    Public Enemy #1
    WTF did you pull this out of or what the **** where you planning on putting it in! thats one hell of a set-up!
    In the Fucking A
    Quote Originally Posted by TransAxle
    It was going in my 2000 Ford Mustang, but I sold it. I was going to keep it and put it in a Cobra kit car but I don't have the time or money to build one like I would want to right now.
    In the Fucking A
    bumpage
    rolla rollin
    middle GA
    this bit would be bad in a 90 to 93 coupe mustang! gl with the sale man
    villa rica, ga
    bump for an awesome motor!!!
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    In the Fucking A
    Thanks man, with the right setup this motor has got 8s in it no problem.
    In the Fucking A
    Quote Originally Posted by NevrNufTorq
    Thanks Dave
    What is the compression height on the pistons, and how much ring land do they have? Also, what kind of work has been done to the heads, and who done it? Do the rods have std rod bolts, or the upgraded bolts?
    mcdonough
    is it a 427 cobra jet
    In the Fucking A
    Quote Originally Posted by Init2winit
    Ill have to go find the build sheets as I don't remember the compression height of the pistons.
    The heads were raw 225 AFRs that my machine shop sent out to have some CNC work done Ill shoot them a call and ask who it is they use. The rod bolts are upgraded ARPs.
