Thread: DEL SOL LS swap question
    95 teggy for parts DaRussian's Avatar
    Default DEL SOL LS swap question
    ok im putting a OBDII ls motor into a 94 del sol, do i need to switch it to obd1 or anything like that? is it same as a civic? and which axles do i use?
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    Wheres the money?
    McDonough
    to keep it obd1 get an obd1 alternator, obd1 injectors, and obd1 dizzy. to make it obd2 get the conversion wires for your ecu.
    Athens/ATL
    ^^What he said. Your del Sol is OBD1, so I would suggest just converting the OBD2 engine back to OBD1. Makes it easier.
    Augusta Ga
    ls's are FUN ... but my gsr is funner @!!!!! do wut the first guy said !!!!
    93 sol Si
    95 sol S
    95 sol Si
    Athens/ATL
    Eff your b series... H22 sols are tits.
    Senior Member boosted b's Avatar
    keep the obd 1 setup less work
    Lsu tigers going # 1 again
    ok but what do i have to do to just keep the motor obd2 since it already is OBD2.?
