Results 1 to 17 of 17
Thread: FS: 46in Samsung LCD 720p TV
    Default FS: 46in Samsung LCD 720p TV
    up for sale is my BALLIN SAMSUNG 46in LCD TV
    SPecs
    Model Number-LNT4642H
    46 inches
    720P LCD
    3 HDMI
    PC in
    # Widescreen aspect ratio High-definition 1366x 768 pixel resolution:
    High resolution pixel density with built-in image scaler to handle inputs from a variety of digital and analog audio/ video sources
    # 7000:1 contrast ratio/500nit brightness:
    As two of the most important determining factors in overall picture quality, contrast and brightness levels achieve new heights in this latest generation LCD panel. Samsung's new LCD TV's give the most stunning realistic picture quality ever from a flat panel set.
    # Wide color enhancer:
    Wide color enhancer optimizes a color's hue resulting in more natural colors.
    # CCFL - Cold Cathode Fluorescent Lamp:
    Provides colors in your picture that were not available before.
    # 178 degrees (H) / 178 degrees (V) viewing angle:
    Wide viewing angles improves viewing angle, contrast, and brightness to provide an even better picture.
    # Built-in digital tuner: (ATSC/Clear QAM)
    High-Definition Built-in tuner receives and decodes digital standard-definition and HDTV signals from over-the-air broadcasts (antenna required)
    # Fast 8ms response time:
    Fast 8ms response time minimizes blurring of moving video.
    # Picture-in-Picture: (PIP)
    Picture-in-picture enables convenient simultaneous viewing of TV programs and video or PC sources.
    # Game Mode:
    Game mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games at the touch of a button.
    # V-Chip system:
    This allows blocking of rated TV and movie programs determined by the parent to contain objectionable content.
    # Trilingual on-screen display:
    Displays options in English, Spanish or French.
    # Sleep timer:
    Variable sleep timer turns the TV off in varying time intervals.
    # Speakers:
    Side built-in speakers with 10 Watts x 2 audio power
    # SRS TruSurround XT:
    TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any two-speaker playback system, including internal television speakers and headphones. It is fully compatible with all multichannel formats up to 5.1 channels.
    # Sound leveler:
    Audio volume automatically stays consistent during channel changing.
    # Side A/V ports:
    Provides easy connections so you can connect a camcorder, digital camera, or any other digital device with no hassles.
    # Removable swivel stand:
    If you want to install your TV on your wall, you can easily remove the stand and use a compatible wall mount to safely and stylishly attach your TV to the wall. See our recommended accessories or TV essentials bundled packages.
    # Auto wall mount compatible:
    3-dimensional operation via TV?s remote control; no external IR receiver required.
    # Inputs & Outputs:
    3 HDMI High Definition Multimedia Interface (2 rear/1 side), 2 Component video inputs, 2 S-video inputs (1 side/1 rear), Side and Rear A/V inputs, PC input, USB 2.0, 2 RF antenna inputs, Headphone jack.
    # Dimensions & Weight:
    TV w/o stand: 48" (W) x 27.9" (H) x 4.4" (D) / 49.8 lbs.
    TV with stand: 48" (W) x 30.6" (H) x 12.8" (D) / 61.7 lbs.
    More Product Information for the Samsung LN-T4642H - 46" High-definition LCD TV w/ integrated ATSC tuner (Refurbished)
    It's easy to see - and hear - why Samsung's LN-T4642H is an exceptional value. It offers everything you want in a 46" wide-screen HDTV LCD, including a sleek, gloss-black frame to enhance any d�cor.
    The 720p resolution and a 7000:1 dynamic contrast ratio combine in a remarkably crisp, high-quality picture with deep blacks and brilliant color, while its fast 8ms response time delivers smooth action sequences.
    SRS TruSurroundXT produces full, 3-D sound from two side speakers. Full connectivity, including three HDMI ports, lets you plug in everything from PCs to video cameras and more.
    Specifications
    General Information
    Manufacturer Samsung
    Manufacturer Part Number LNT4642H
    Manufacturer Website Address www.samsungusa.com
    Product Model LN-T4642H
    Product Name LN-T4642H 46" LCD TV
    Product Type LCD TV
    Technical Information
    Actual Screen Size 46"
    Compatible Technology HDTV
    Response Time 8 ms
    Video
    Video System ATSC
    Video System NTSC
    Channel Coverage 181 - (VHF 2-13, UHF 14-69, CATV 1-125)
    Audio
    Number of Speakers 2
    Total Output Power 10W
    Audio Decoding Stereo
    Interfaces/Ports
    Ports 3 x HDMI
    Ports 2 x RF
    Ports 2 x Component Video In
    Ports 1 x S-Video In Side
    Ports 1 x S-Video In Rear
    Ports 1 x A/V In Side
    Ports 1 x A/V In Rear
    Ports 1 x 15-pin HD-15
    Ports 1 x
    Power Description
    Input Voltage Range 100 V AC to 120 V AC
    Frequency 60Hz
    Physical Characteristics
    Dimensions 30.6" Height x 48" Width x 12.8" Depth - With Stand
    Dimensions 27.9" Height x 48" Width x 4.4" Depth - Without Stand
    Weight 61.7 lb - With Stand
    Miscellaneous
    Additional Information
    Ports Description:
    # 2 x RF: In
    If you google search you will see these TVs going for $1300-$1800 pretty much everywhere. This TV is VERY RARE because it was the last of the 720P 46in LCD TVs ever made and ALOT of people want them. Picture quality is excellent, i paid $1700 for it approx 1 year ago.
    PICS
    IT WILL COME WITH THE WALL MOUNT FREE!
    Ill include a 6ft HDMI cable for free as well. To be honest, i do not know where the factory stand is, ill have to look for it i just moved and dont know where it could be.
    PRICE
    $950 FIRM FIRM FIRM
    NO TRADES
    NO TRADES
    NO TRADES
    Unless you have a 52in-55in and i add cash.
    Need to sell to make way for my new bigger TV.
    PGGAY AND TAG MASTER
    you just mounted it.....it is to soon to take it down. by the way ill stop buy tomarrow or this weekend and drop off that hard drive...
    ok cool Party SAT Night for Peters BDAY
    CLiff im buying a 55in so this has to go
    i got 20 bux on it today only....
    up
    Sol_boosted k20siboii's Avatar
    bump for a nice tv
    i have the same stand for my ps3
    Fake Suburban Environment
    Damn....
    hmmmmm
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    nice addition to any home ill even demo my PS3 on it, you wont find a nicer 720P, it looks better than some 1080P tvs too
    I will give you 2 goats and the cassette deck in my 1988 Chevy Accord. No more, no less!
    1997 M3/4/5
    2004 X4 4.4i
    up
    950...hmm....nice deal. gl
    up
    '05 GSX-R 750 Sushi's Avatar
    Mall of GA
    Bump for an AMAZING DEAL and a Great LCD TV!
    Note: You could use this as a computer monitor too!
    2005 Suzuki GSX-R 750
    Jan 2003
    kennesaw ga
    nice tv! picture on these things look alot better than my plasma
    N/A POWAH! Gorilla Eg!'s Avatar
    pmed
    no trades cash only
    fo sho
    L-ville
    great deal if gas wasnt running out i would pick it up lol... nice sale tho
    02 Metallic Blue IS 300
