Results 1 to 25 of 25
Thread: 1995 Nissan 240sx SE For Sale...KA-T!!!
    Milledgeville,GA
    Default 1995 Nissan 240sx SE For Sale...KA-T!!! OR WILL PART OUT PRICES BELOW
    For Sale:1995 Nissan 240sx SE (automatic)
    GOING TO PART OUT THE CAR FOR GREAT DEALS!!!!!!!!
    ka24de-t. 165,000 miles on chassie $5000 THE WHOLE THING
    tHE SHELL OF THE CAR LESS THE MOTOR $1000
    Here is the low down on my baby that I am putting up for sale. I can't afford to keep going with this car.It has a freshly rebuilt motor that is an upgrade from the old race motor that I ran for 2 years.The car was a beast.Ran 7.1 in the 8th at 101mph and pulled hard as hell,yes stock automatic tranny. These trannies are strong I don't care what anybody says. Well here are the stats on the car.
    DON'T LET THE PART OUT PRICES PASS YOU UP THEY ARE A STEAL
    The whole motor was disassembled and redone the whole way
    Motor work(bottom end)
    -Block was cleaned in a vat
    -All surfaces were decked
    -The cylinders were bored 20 over and honed
    -Arias 8.8:1 compression pistons(20 over bore) and wrist pins
    -Top seal rings(all gapped to spec)
    -Crankshaft was balanced along with whole rotating assembly
    -The crankshaft journals were polished
    -Carillo K1 serries h-beam rods
    -Calico coated main and rod bearings
    -ARP Rod bolts
    -Cometic head gasket
    -ARP Moly lube used on all bolts when assembly was done
    -All oil sqrirters were cleaned
    -block was the painted hemi orange with engine paint
    Head work
    -The heads were cleaned in a vat
    -The head was pressure checked
    -Mild port and polish done on exhaust side
    -valve guides replaced were nescessary
    -New locks installed and seals
    -Ferrea valves
    -Ferrea dual titanium valve springs
    -Ferrea titanium retainers
    -Three angle valve job
    -All valves shimmed properly and special washer seats put below second spring to keep away from wear on the heads
    -Stock cams
    -Fairly new factory timing chain assembly
    -ARP 10MM Head stud kit
    -Valve cover paint hemi orange
    -Mr.Gasket copper exhaust manifold gasket
    -Intake manifold was stripped of all emissions parts and cleaned(all heater hose ports capped off also)-THE WHOLE ENGINE FOR $2100!!!!!!
    Fuel system and electronics
    -Precesion injected 75lb injectors AND DSM Ohms converter
    -AMS Turbo 240 fuel rail(really trick with nice engraving)
    -Walbro in tank fuel pump
    -Bosch adjustable fuel pressure regulator- THE WHOLE FUEL SETUP $470
    -EMance performce ecu tune-$240 COST ME ABOUT 400
    -SAFC2 piggybacked on to it for fine tuning-$280 WHAT A STEAL
    -10.2mm spark plug wires-$30
    -Apexi Turbo timer(not hooked up)-$40
    -Stewart warner boost gauge-$25
    -Cyberdyne digital oil pressure gauge(has not be put onto the new motor)-$35
    Turbo setup
    -T04S Turbonetics turbo with polished compressor housing(front side)-$275
    -Rev-Hard exhaust manifold
    -Turbonetics wastegate-MANIFOLD AND WASTEGATE $175
    -HKS Blow-off valve(not yet put on the new motor,I changed the last piece of innercooler pipe to fit in with the new radiator)
    -XS ENgineering inner cooler setup-$225
    -XS Engineering downpipe-$80
    -Straight through exhaust to the HKS Hi-power exhasut system(cat-back)-$300
    -300ZX Mass airflow sensor-$120
    Cooling system for motor
    -Summit racing 3 row aluminum radiator(custom setup,it is for a big block chevy)- $135
    -CSR Electic water pump-$135
    -Custom radiator hose setup(was expensive to drive back and forth to the auto parts store to get hose to fit right).
    -B&M transmission cooler-$50
    Tranny setup
    -Stock 1995 transmission(roughly 65,000 on it, got it for free so I installed it)
    -Alpine industries stage 2 torque converter
    -New transmission filter and fluid
    Interior is stripped out of this car and there is one seat Sparco Speed seat with Sparco mount- $120
    The whole interior of the car was painted along with the outside custom flame job. The car has not stereo,no heat, no power steering,no a/c, nothing. It is a drag racing car. Extras with the car an extra altenator, extra distributor,has the stock rims along with a set of 18inch Katana 5 spokes, and drag slicks on their own rims 15by 7.5inch rims. This car is a building project I do say it needs some fine tuning on the idle it runs a little to rich and a roll cage needs to be installed or don't. I was in the process of having that done and having a metal plate dash installed and the money ran out I had to stop. The car does run and this motor has maybe 30 miles on it, I just did the first oil change. The new motor has not been raced yet and will be a great car the race if looking for a track terror. I am probably forgeting stuff but e-mail me(Tyler) at [email protected] or call me at 1-478-363-5043(no calls past 11pm please) and don't let this deal pass you up.My car has just came up for sale and I know will sale quick at this price estimated value of what it has cost me is around $12,000 Make offers if you like I will have more pictures to post in the next couple of days.
    -The bottom 2 pics are of the newer motor. It does not look much different because I painted the motor the same color the second time around.These new pics display the fuel setup and other goodies.
    Attached Thumbnails Attached Thumbnails -dsc00179-jpg   -dsc00190-jpg   -dsc00181-jpg   -dsc00480-jpg   -dsc00481-jpg
    i need ae86 parts canadianrcis's Avatar
    marietta
    nice car, sucks that its auto.
    hachi roku groove
    Milledgeville,GA
    and also obo on this car, don't let this deal pass you up. If you know anyone in the Milledgeville,GA area and ask them about Tyler's 240 they will tell u it is a steal at the price I am willing to let it go at....
    Milledgeville,GA
    Also I have a scion Tc that I may possible sale 2005 5-speed release series(1899 of 2000 made) with 38,000 miles. Red and awesome car $13,500
    Unknown
    how much you think you pushing
    Milledgeville,GA
    Not sure at the time. The new motor has only like 30miles on it and I have not even full throttled it. The tune that was put on the car is for 16lbs of boost and was estimated to make around 388 rwhp.I was thinking it would be more because that is based on a fully dressed motor and mine is very non-restricted
    Milledgeville,GA
    Please give offers on car if interested. No reasonable offer will be refused
    Milledgeville,GA
    Going to list the 240 for one more week and then I will putting the car on ebay for a higher amount. For the final running week on this add I am offering the car for $5200 really don't pass this deal up. I am needing to sell this car!!!!
    Grayson GA
    interested in a 74 camaro. 7k miles on motor with mods. perfect body
    Grayson GA
    i can finish what u started as i am about to start school again and need a project vehicle for school
    IA Member mouzzer's Avatar
    hehe I went to college in milledgeville ( shoots self )
    $5000?
    US Airborne Infantry LRS
    eeeeehhh tired of the desert
    Milledgeville,GA
    5000 is a little low I will take 5200 at the lowest offer did bottom offer.
    Milledgeville,GA
    There is a listing for the car on ebay with new pics of the new race motor. The motor you see in the pics here is the old race motor. It is listed as Nissan 240sx KA-T if you want to see the new pics. The camaro deal is an awesome offer and I will consider if the people interested in the car actually do it or not. This car is a mean beast!!!
    Milledgeville,GA
    $5000 is the bottom sale price on the car now. This is the final selling price on the car.
    Monroe, Ga
    trade for the car in my sig?
    Milledgeville,GA
    sale only
    Milledgeville,GA
    car still for sale due to a a non-paying buyer(check didn't clear)
    i got 3k plus 90 celica
    Milledgeville,GA
    what year is the celica? may consider
    Milledgeville,GA
    The car is up for parting out check out the great deals!!!!!!!!!!
    Rome,Ga
    if the car is xcomplete i will trade u my built da integra its built for boost..
    Milledgeville,GA
    nOT THE TRADE i AM LOOKING FOR AND THE CAR IS STILL WHOLE RIGHT NOW.
    Milledgeville,GA
    The car is on another price drop. The car is still whole for the time being and will sell for $4000 bottom offer so take it before it is tAKEN APART AND SOLD IN PIECES!!!!!!
    Everyday im HUSTLIN'
    atlanta,ga
    you nede to post more pics, im interested, but i need to see interior pics rear pics, etc..
    homie dont play that
    hmmm ka-t bump for u man !
    ....True ////OFFSET\\\\
