Results 1 to 14 of 14
Thread: need help ASAP! for computer science class!
    Gwinnett-Grayson
    Default need help ASAP! for computer science class!
    ok so i have to take a screen shot of this thing that i have to do for a lab for my computer science class. i have done everything has asked me to do and im ready to take a screen shot. following the directions and what not and opening up word to paste it in it wont ****ing paste screenshot. Now im using vista, and my computer is a compaq that doesnt just OUTRIGHT say PRINT SCREEN, it has prt sc under the insert button that im assuming is the print screen button. well pressed shift and that button and not **** happen when i put it into ****ing word. what am i doing wrong?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    It's good to be boosted JennB's Avatar
    ITP
    control + print screen then paste
    2005 Mazdaspeed MX-5 -1.8L Turbo
    Gwinnett-Grayson
    it wont do it, its like its not turned on or soemthing
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    hold ALT and tap F4 a few times, then press print screen and hit pate
    DBlock
    tha ville
    as$ hole!!!!!!!!!!.........hahaha .........1
    ALT + F4 a couple of times.
    If the screen closes, then you're doing it wrong.
    You gotta do it real fast for it to work.
    everywhere & nowhere
    Copy it to MS PAINT - then xfer to word. Also try FUNCTION + PRT SCR, not SHIFT.
    Gwinnett-Grayson
    lol yall are gay thats gay ass old trick
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    BTW - if you can't even PRT SCR, you are in the wrong class already. You're gonna be hatin' life when they actually make you print to the actual printer - ur gonna be f*cked.
    do ctrl + prtsc then paste it in paint.
    ok i also just did it in word and it worked. make sure you hold down ctrl AND press prtsc WHILE holding down ctrl
    Smyrna
    On most laptops you have to hold the function key and press print screen.
    LOL man you're off to a rough start. Have you done any ipchains work or set up any PDCs yet? Oh yeah try PINE for a text editor instead of notepad.
    ITP
    I know, right. I have a degree in Comp. Sci.... it's going to get a LOT harder. LOL.
    Anyway, are print screen and insert on the same key or is it on a key under insert?
    If it's the same key, as was said above, you have to use the function key.
    Interwebs terrorist Friggintitsman's Avatar
    You need to feed your computer the souls of Peruvian children before it will perform such a task.
    I thrive on caffineand HATE
