I installed a JDM type-r gauge cluster in my 95 integra, everything went smoothly but when I turn the car on the ABS light stays on...does anyone know whats wrong? I can't figure it out.
GECKO SQUAD
does your integra have ABS?
There are 2 things you can do....Originally Posted by Skillet
1) buy a '96 spec ITR gauge cluster and it will be plug and play for 94-97 integras. The one you have is for 98+ tegs.
2) switch the green film on the back of the ITR gauge cluster with your stock 94-97 cluster and everything will work fine.
I've been in your situation before, had to find out the hard way.
I have already switched over the green film, which is why i'm so stumped over this damn ABS light.Originally Posted by IntegraXTR
but i'll look into what year cluster i have....thanks
GECKO SQUAD
yesOriginally Posted by Benefit
GECKO SQUAD
wat i did is i swap the jdm gauges out and put it in the 94-97 cluster housing with the bezel, i didnt have to swap the green film and it worked for me
removing the bulb is the easiest way. who cares about an ABS light? I always took out the SRS light bulb when putting in aftermarket wheels and removing passenger air bags. So much easier.
^^ yeah spoolin is right too... u dont really need the srs and abs light just take the bulbs out
Originally Posted by SPOOLIN
GECKO SQUAD MEMBER
MSS RACING REPRESENTA.....
the saga continues....
