Page 1 of 4 1234 LastLast
Results 1 to 40 of 122
Thread: Tunerfest 1/4 results...
    Woodstock
    Default Tunerfest 1/4 results...
    my best time was 14.2 @ 97.01...
    Val RIP
    my only rule in life
    post the whole slip you plane jacker.
    Woodstock
    Quote Originally Posted by S&Wautomotive
    i don't have a scanner you kok knuckle!!
    but i have one at work...so i'll scan it in tomorrow you bastard former non rear power windows having motherb1tch...
    Val RIP
    i don't have a scanner you **** knuckle!!
    but i have one at work...so i'll scan it in tomorrow you bastard former non rear power window having motherb1tch...
    just type what your RT, 60ft, 1/8, ect was.
    dont lie either ricer
    Woodstock
    RT: .987
    60ft: 2.247
    330: 6.022
    1/8: 9.169
    MPH: 78.33
    1000: 11.892
    1/4: 14.216
    MPH: 97.01
    Val RIP
    RT: .987
    60ft: 2.247
    330: 6.022
    1/8: 9.169
    MPH: 78.33
    1000: 11.892
    1/4: 14.216
    MPH: 97.01
    was that your best 60ft of the night? 2.2 is pretty good for that track last night on street tires.
    you should call out thacker
    Woodstock
    yes it was my best of the night...Launch Control ftw.
    LOL i'll think about calling him out...but i only have flash and that's it
    Val RIP
    My best out of 3 was:
    60': 2.4
    1/8: 9.5
    1/4: 14.5 at 99 mph
    Hiawassee, GA
    R/T: .078
    60': 2.4
    1/8: 8.6 @ ?? (Cant remember, and lost the slip sometime last night)
    1/4: 15.16 @ 88 LOL.
    Couldn't get it to shift from 2-3 at WOT, so right after the 1/8th I let off and coasted through. Need to get a VSS, and my shift points reset to get an accurate time. With a decent 60' hoping for a high 12.
    -Zach-
    1987 Toyota Pickup - Toy
    Woodstock
    Quote Originally Posted by KevinT707
    60': 2.4
    1/8: 9.5
    1/4: 14.5 at 99 mph
    was that you i saw pushing your car while you were in the staging lanes?
    Val RIP
    13.88@ 104 mph
    60ft: 2.39
    Worst time: 16.25 @ 94mph. Epic last run of the night. Spun first to redline, bogged second, missed third gear. LOL
    Buslengths behind you
    Quote Originally Posted by 03RCode
    R/T: .078
    60': 2.4
    700r4?
    u not manual shifting it?
    Hiawassee, GA
    700r4?
    4L60E. Tried one pass manual, and one not. Didnt shift either time. Does fine driving normally, just not at WOT. Seems to be a common problem with them with the VSS goes.
    -Zach-
    o,ok...yea i got a 91 305 w/ 700r4 and seems little faster manual shifting,but then again stock shift points suck so hard
    Hiawassee, GA
    Yeah there was only .04 difference between manually shifting it, and just pointing and shooting it. I got some good SBC parts if your interested PM me. Cam, intake, carb, etc.
    -Zach-
    13.8 at 102
    i gots a 700r4 as well. but no motor to pair it up with. and the trans is mildly built
    NoRth_SyDe NiSSaNs wunquikser's Avatar
    ve sentra checking in...
    M/T slicks
    60ft : 1.9
    1/4 E.T. : 13.6 @ 100
    Street tires
    60ft : 2.3
    1/4 E.T. : 14.2 @ 98 mph
    92 sentra ve'd
    COME GET SOME!! 191whp 150wtq N/A
    i got a LT1 with no tranny
    This was my best ET and 60':
    R/t------.189
    60'-----2.257
    330'----5.992
    1/[email protected]
    1000'---11.244
    1/[email protected]
    This was my best Trap speed:
    R/t------.200
    60'-----2.492
    330'----6.131
    1/[email protected]
    1000'---11.326
    1/[email protected]
    conclusion: Next mod = drag radials
    combine those together and it sounds like a good drivetrain for a good ole fc
    Banned ILOVEKIDDRACING's Avatar
    Palmetto, GA
    R/T: .078
    60': 2.4
    8.6 with a 2.4 60'?
    LOL.
    You have mid 11 second car if it would hook.
    Jan 2003
    Quote Originally Posted by ThackerSS
    8.6 with a 2.4 60'?
    LOL.
    Really?
    I had a 2.2 60', 8.5 1/8th, and my car is no "11 sec" car. Where exactly do you get all your numbers from?
    It's just a Sentra
    Gwinnett, Georgia
    I was in the black Nissan 200SX
    RT......244
    60'......2.250
    1/8.....8.814
    1/4.....13.125
    MPH....115.68
    I seriously need some slicks even with the drag radials I couldn't get traction.
    "If you want peace, prepare for war"
    Palmetto, GA
    Quote Originally Posted by Jaimecbr900
    Really?
    If you cut that 2.2 down to a low 1.6 or 1.5 you've knocked off .6 in the 1/8th.
    That alone gives you a 7.9, however when you cut that much off your 60 you can typically get even more off the 1/8th. So lets say with a 1.6 60' you cut a 7.8 - 7.9
    7.8 in the 1/8th is roughly 11.8 - 12.0 in the 1/4th. Even lower with a good geared back halfing car.
    My camaro did some 7.45 // 11.5-11.8 runs.
    The math is easy to do.
    My GTO ran some low 8.2's and ran 12.7 in the 1/4th.
    Jan 2003
    Really?
    Well, I have cut 1.8 60' times more than once. My car still wasn't in the 11's. Trapped over 112, still wasn't in the 11's. Ran at your favorite uber faster than anything else track, and still wasn't in the 11's. Bottomline? I don't have an 11 sec car any way you slice it, yet I've hit all the numbers your magic calculator says will net me an 11 sec pass.
    Considering that I beat both your 60', 1/8th, and 1/4 times on the same exact track, on the exact same night, under the exact same conditions........does that now make me the king ding-a-ling launch master now then????? I mean since we're using magic calculators and stuff.
    Palmetto, GA
    Really?
    Sigh.
    112 mph is plenty to get into the 11's. It would be VERY high 11's, but if it hooked it'd be in the 11's.
    Cut a 1.5 - 1.6 60', and then run 112 mph and your ass is in the 11's.
    A 1.8 isn't going to get you into the 11's with a 112 pass.
    YOU don't have an 11 second car, because your **** doesn't hook.
    Sigh.
    I got a 1.7 60ft with a 110 trap speed and got into the 11's
    Palmetto, GA
    Quote Originally Posted by WickedIXMR
    Exactly my point.
    Anytime I see a car that runs 110-113 mph that is in the 12's or 13's... I think that car has 11 potential if the guy would drive it, and make it hook like it should to be a quarter mile contender.
    Suspension, drivetrain, and then power. If you want a car that works on the dragstrip.
    Sadly, you boys only seem to be interested in the "look how big my dic.k is" idea of racing. You add all this HP.... do nothing to make it hook.... and then you all go doing rolling starts like nascar or some ****.
    Jan 2003
    Sigh.
    Whatever dude. Keep guessing and pulling numbers out of your a$$. I don't care.
    My "sh!t" doesn't "hook", yet it "hooked" enough to beat YOUR super duper launch machine...by a lot.......what's that say for you?????
    I'm so tired of arm chair QBs and all this talk about shoulda, woulda, coulda......:jerkit: It gets old. Especially since stock G8's were running same or better times than you were with your so called-stock machine. I also noticed that if the amount of people around you last night is an indication of the amount of friends you have IRL, then I understand your bitterness and boasting since it must be very lonely when off-line.
    Stop talking all the smack already like you're some kind of racer. I was doing real racing in real American muscle cars and imports when you weren't even a tad pole in your old man's scrotum, yet you don't see me going around patting myself on the back like I'm the John Force of street racing. It gets old dude. REALLY old. After seeing your launching and racing prowess first hand myself right before you busted out a remarkable 13.9 and YOU got walked.....I wouldn't beat on my chest too damn hard. Where did you go after that? I was figuring you'd come back around to redeem that shattered ego of yours. What happened?
    Palmetto, GA
    LOL. What are you talking about?
    My GTO has been on jack stands for about 2 weeks now, I've got 2-3 people that can confirm that. It hasn't left my house.
    Infact, I got a ticket stub from seeing Death Race saturday night at 9:50 pm at Carmike Cinemas in NEWNAN, GA.
    Whoevers car you saw run , DEFINITELY wasn't mine.
    Was the car missing its spoiler? Was it on 19" Black Chrome NICHE rims? I highly doubt it. That is funny tho. You see a ****ty driver in a slower truely stock GTO and your nuts flair up. Maybe you should call me out to the street?
    4rd WHAT? SicStang03's Avatar
    Sandy Springs/Dunwoody
    R/t------.189
    60'-----2.257
    330'----5.992
    1/[email protected]
    1000'---11.244
    1/[email protected]
    R/t------.200
    60'-----2.492
    330'----6.131
    1/[email protected]
    1000'---11.326
    1/[email protected]
    You did better than me my first time out to the track when I was stock. I haven't been back since the mod bug bit though
    Quote Originally Posted by coolcat View Post
    NO SHIT AT ALL I JUST HAD MILK AND A COOKIE. I DIPPED THAT BITCH AND EVERYTHING, SORT OF LIKE I DID MY NUTS INTO YOUR MOTHERS LOOSE VAGINA.
    That......would be my bad. Sorry.
    Non-Turbo NoRotor's Avatar
    I'm gonna have to go with Thacker on this. Generally speaking, his argument is valid and true. He's pretty much on-point.
    Wheel-hop ftl but yay for power on the top-end. Ask me how I know, haha.
    Banned GirlieZ's Avatar
    boise
    hi justin!
    Norcross, GA
    According to statistics, calculating collected data from past time slips and current records on a certain car - Thacker seems to be pretty accurate with this post. To some extent, why? Because unlike him, Jaime doesn't own a Camaro/GTO, so this theory is invalid since every car isn't going to perform the same. And just because one car traps 110 and hits an 11 sec pass doesn't necessarily mean another car will too. Common physics.
    Palmetto, GA
    Quote Originally Posted by meepnork
    The physics come into play, mostly in how the car leaves the line.
    Some cars just don't hook. A lexus isn't a "hooking" car. Never will be.
    Exactly my point.
    You are an idiot. How about tires... Thats what makes a car work (60ft) on the drag strip.
    http://www.youtube.com/watch?v=YGG00btQvFg
    There is a lexus cutting a 1.36 60ft. Not bad for a NON hooking car What kind of 60ft's have you run?
    -Clark
    ~~I Like the ****~~
    Dam good times my best is still 12.8 @ 118 on 225's Guess I need the Tire mod =*(
    My current vehicles
    04 A4 GTO
    02 A Camry
    Jan 2003
    "Never" will be????
    Any car can be anything they are built to be. If I didn't want A/C, Leather heated seats, Cruise Control, Traction Control, Climate Control, PW, PDL, PW and heated mirrors, full stereo, TV's, amps, speakers, BBK, completely STOCK motor.....I could do this all day long you know.....then I would've built me a car that would run on the 1/4. But since I just have a DAILY DRIVER, with 150K+ to boot, then I'll just leave all the macho chest pounding about your car "hooking" on DR's to you. How about that?
    Quote Originally Posted by Clark94T
    -Clark
    Here you go Thacker......a REAL racer speaking. Funny how a Lexus doesn't "hook up", huh? Like Clark said, you're an idiot.
    Like I told your young punk a$$ before, you THINK you know about "racing" when you're no more than Monday morning QB pulling numbers from thin air that coincide with your ego.
    Clark, this kid loves to talk a ton of smack but keeps his super uber secret race track numbers from his so-called "stock"....wink, wink.....GTO to himself because like all good street racers he wants to bait people into street racing. Yet ironically enough I saw a guy that looked identical to him, driving a blacked out GTO, with black wheels, no spoiler, GF in the car, that cut an uber fast and blazing 13.9 in the super duper end all "hook" car.....
    He claims to be the one and only "stock" GTO to be in the low 12's or something like that. Because we all know that there are tons of production "stock" cars busting out 12's right off the showroom floor.
    Whatever. He just gets on my nerves with all his constant bragging and opinionating.
    Certified Gearhead SleepingTalon's Avatar
    Alpharetta, Georgia
    A lexus can't hook? Do you even think before you type? I can show you about two dozen examples of a Lexus "hooking".
