Results 1 to 29 of 29
Thread: MY 1ST GEAR V-TEC WON'T WORK????
    Senior Member AMD_Civic's Avatar
    Default MY 1ST GEAR V-TEC WON'T WORK????
    just wanna know why it isn't working...?? someone know anything?? from 2nd to 5th it all works except for my 1st....
    JDM TYTE AnthonyF's Avatar
    What gear you are in doesn't affect if VTEC kicks in or not. Maybe you just aren't hearing it? Check your oil level 1st. It's the easiest first procedure.
    -Ant.
    The Carbon Fibered R6
    clayton county
    it could be that your 1st gear is going by too quick for you to tell if its engaging or not, thus why you feel it in 2nd and so fourth..... but if it really isnt working in 1st gear change your speed sensor
    I give out reps....
    1010011010 Atlblkz06's Avatar
    Hell
    Can you actually hear the VTEC?
    I have an older 98 Accord with VTEC and I dont hear or feel anything when it suppsedly changes at 5400rpm.
    Accords dont "kick" as much as Civic's do. The Accord is heavier and doesn't feel the response like the lighter Civic's do.
    -Ant.
    West Staines
    Honda 1st Gear = Useless to begin with
    if yo' vtac dont work period then lets talk.
    Swat Yourself. rsxtype-svi's Avatar
    Orlando, FL
    Quote Originally Posted by Atlblkz06
    lol dude.......sohc VTEC is not NEARLY as nice as DOHC VTEC...especially in that heavy car..you do have vtec but its very calm lol.....now for the gsr, VTEC is heard and felt in all gears so this is a tough one
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    ah i see yall can tell vtec kick in if you hear VTAAKKKK. I m deaf but i can tell vtec kick in BY FEELIN IT. COOL!
    NIKON Squad member 05
    Mah shit thread
    AP2 FTW Zeeb's Avatar
    Dunwoody
    My first gear is fun... But
    To OP:
    Maybe you dont know anything about cars and you have no idea whats going on?
    StudioZDesigns
    Quote Originally Posted by Arsenal75
    Topdown for miles make vertical smiles.
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    correct me if I am wrong but there are 3 things that control vtec.
    1.oil pressure
    2.engine temp
    3.engine speed
    so if the car is warm and has oil and you have done nothing to change the ecu vtec crossover then your car is the rare 2nd through 5th gear vtec(j/k). It could be your temp sensor. If it doesn't work then your car won't go into vtec. Check your vtec solenoid.....aka clean it out if the screen is clogged. Make sure you have oil so that you are making enough oil pressure. Also....but not likely.....your oil pump is going out and maybe not making enough oil pressure to switch vtec on.....just my 2 cents, im not a mechanic but have had this problem on many hondas.....hence why I have the car in my sig.....hope this helps
    VTEC not working eh... sux for you haha!! oh check your oil see if it's low :UR::
    Deuce Deuce BB1_Luda's Avatar
    I dont know about your engine or about sohc vtec
    But with my H22 Dohc Vtec, if VTEC is not engaging then my stock ECU sets the limiter to about 7200rpm.
    When VTEC is working the limiter is at 8000.
    Is the rev limiter lower in first gear then all the other ones or is it same throughout all gears?
    my oil and everything works fine.. i always let my car warm up before i drive... and on 1st gear i slowly just step on it to where vtec should pop and it doesn't... so iono either.. i heard it might be my ecu also... any more suggestions..
    2slow4u
    P-town
    ^ HONDA GOT V-TAK ...damn i didn't even know that..! well i don't hear mine.guess i 'm not hittin hard..lol...
    workin on it!
    b/c you scared to run meeh son..!!
    Quote Originally Posted by mengus200sx
    Macon
    Quote Originally Posted by AMD_Civic
    If I remember correctly, the ecu doesn't know what gear you are in. It runs the same fuel/ignition maps and vtec engagement point in every gear, so it wouldn't keep vtec from engaging in first.
    Land Rover LR3 HSE
    everywhere & nowhere
    The 1st thing is to check and see if you are throwing any codes... do that, then post back in here.
    Crash
    Snellville, GA
    this is a tough one...
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    yeah well imma check it out though.. try all that i can and it still don't work...!!!sucks...
    is it a stock or chipped ecu?
    you said you're just trying to roll into it...i assume you mean you're not got wot to check. have you tried wot?
    NW ATL
    What's "V-TEC"?
    Savy boi... EFlove's Avatar
    Smyrna, GA
    I've read through these posts and laugh. V-tech can be quite perplexing. I have 2 ecu's, both chipped with 2 totally different maps. On ECU #1 my V does not engage in 1st or 2nd, however the other ECU will allow engagement throughout. Where's an intelligent answer for this? Yes my vtec pressure screen is clean, plenty of oil, new oil pump, temp sens. is good, and motor is warm.
    Clean tach signal to the ECU? Also have you tested the "workinga" ECUs in other cars? You never answered if you are throwing ANY codes.
    Senior Member G.C's Avatar
    Forgot
    hey EFlove when you say you cleaned the vtec pressure screen. how did you clean it?
    Heard VTEC Solenoid = non servicable. if your screen was clogged then something else was wrong with your car that made all the trash go to the solenoid.
    :idb:
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    things that control vtec are rpm,throttle position,coolant temp,vehicle speed sensor,oil pressure sensor according to the chilton, unless its chipped then you can control all this in the tune.
    well i never had time to check yet... but when i got the car the guy says that its o2 but never checked yet though.. and i still have to get a hold of another ecu to try it out...
    just hook vtec up to a button and vtec whenever you want. lol.
    no seriously, do it... it's fun.
    Southside of The Jungle
    I'd like to see how that gets wired up
    12 volt source to the green wire going to the vtec solenoid...
