Results 1 to 11 of 11
Thread: Fuel Supply System b20b/pr4(obd0)
    gwinnett
    Default Fuel Supply System b20b/pr4(obd0)
    Im throwing this code, and sometimes my car keeps idling from 1k to like 1.5k and then sometimes its set at 2k. my question is that my fuel pump is bad or my fuel filter is clogged up one of the two ? It's a 91 hatch dx with a b20b in it, pr4 ecu. I'm throwing code 43, which is fuel supply system.
    Crash
    Snellville, GA
    i would say check your fuel filter first. gettin crap in it will cause your car to idle all funny like that. if it aint that could be the fuel pump. how lond has it been since you last changed your fuel filter?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    gwinnett
    It's got 129,000 miles on it, i bought the shell when it had the old fuel filter when it had 123,000 miles. It had the fuel filter and the fuel line, just no motor.
    Crash
    Snellville, GA
    so it has 6000 miles on that filter right?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    gwinnett
    Quote Originally Posted by suprapower
    No, current mileage on it. The filter has never been replaced, I bought the shell the filter was already there with the fuel lines just no motor.
    Senior Member G.C's Avatar
    Forgot
    lol then go change it. not expensive. if that don't work then think bout other option.
    :idb:
    also check the injectors
    JDM TYTE AnthonyF's Avatar
    129k? Your lucky the filter even flows if it OEM. Replace ASAP. A clogged filter put a lot of stress on your pump also.
    -Ant.
    The Carbon Fibered R6
    Crash
    Snellville, GA
    yeah man, idk what your thinkin never replacing that filter
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    gwinnett
    Right, reps.
    Crash
    Snellville, GA
    no problem man
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
