Results 1 to 2 of 2
Thread: P600 Mono Amp, Punch3 Sub/box, Cap $250 firm
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Default P600 Mono Amp, Punch3 Sub/box, Cap $250 firm
    I have three things for sale. (All of this for 250$ firm, picked up in gwinnett)
    1.) P600 amp
    2.) 12" P3 Sub w/Box
    3.) Capacitor
    Here are the specs off of the website:
    ROCKFORD FOSGATE P600 600 Watt Class-1bd Mono Amplifier
    Info:
    With its super efficient BD class design, the P600.1bd assures maximum bang for
    your buck when you want to add some serious slam to your system. This is a
    fantastic amplifier choice for a 4-ohm DVC subwoofer or pair of 4-ohm SVC
    subwoofers. For best performance a capacitor is recommended.
    Description Value
    CEA-2006 Compliant
    Number of Channels 1
    Rated Power 325 W x 1 @ 4 Ohms RMS
    600 W x 1 @ 2 Ohms RMS
    Total Power 600 Watts
    Bridgeable No
    Crossover Controls Low-Pass (LP): 35-250Hz 12dB/octave Butterworth
    Infrasonic Filter: on/off selectable, 12dB/octave, -3db @ 28 Hz
    Tone Controls Bass: 0dB to +18dB @ 45Hz
    Signal Input Low level: 1 RCA pair
    Signal Output Low level: 1 RCA pair
    Power Input Connector Block
    Power Wire Gauge 4 AWG
    Speaker Output Connector Screw terminal barrier strip
    Speaker Wire Gauge 8 AWG to 18 AWG
    Heat Sink Type Cast aluminum
    Cooling Convection
    Remote Controls Punch Bass EQ (included with cable)
    Visual Indicators Power On
    Signal Level
    Thermal Status
    Speaker Protection
    Circuit Topology Class Class BD
    Frequency Response 20Hz to 20kHz +/- 0.5 dB
    Dimensions 2.1 x 11 x 13.7 (in)
    5.3 x 27.9 x 34.8 (cm)
    Weight 13.5 Lbs.
    (6.1Kg.)
    MSRP: $445
    One 12" Rockford Fosgate Punch P3 DVC Subwoofers w/ BOX
    Info:
    Rockford Fosgate builds Punch Series Stage 3 subwoofers with advanced cooling
    technology and bullet-proof cone materials so they'll give you years of
    trouble-free bass reinforcement.
    Fibre cones deliver some of the truest low tones you'll ever hear, and they're
    reinforced with Kevlar to add serious backbone to the rich sound quality. The
    extra-tall poly-ether-ester surround extends cone excursion, which translates
    into lows that are full and robust. A colossal 102-ounce magnet calls the shots,
    keeping cone movement under tight control for high accuracy.
    The P3 range of subwoofers features a die-cast aluminium frame, motor cover, and
    trim ring, providing excellent heat transfer and reliable toughness. Rockford
    Fosgate's "Venturi-effect" design increases airflow through the sub's centre
    area for maximum cooling. You get a sub that'll deliver long term performance
    and competition-worthy bass.
    MSRP $269
    BOX MSRP $100
    Rockford Fosgate 0.5 Farad - 20 volt Surge Capacitor
    CPC05-03
    Punch standard 0.5 Farad - 20 volt Surge Capacitor. Ultra low ESR <1.5
    milliohms. Delivers improved sound along with reduced headlight dimming. Up to
    500 watt systems.
    MSRP: $149
    this hits REALLY HARD, if you have wires already in your car you can test before you buy.
    Attached Thumbnails Attached Thumbnails -img_0009-jpg   -img_0014-jpg   -amp-jpg   -capactior-jpg
    Love da wifey Nex's Avatar
    how much is it for all of it ?
