Thread: FS New Vivitek 46D1 46" LCD HDTV 720p in box CHEAP $675
    EM1 Crew Member
    Exclamation FS New Vivitek 46D1 46" LCD HDTV 720p in box CHEAP $675
    Up for grabs is a Brand New in the Box Vivitek 46D1 46" LCD HDTV 720p
    Price $675 FIRM
    Pictures Will be up shortly!
    Specs:
    Product Specifications
    HDTV Compatibility HDTV; Integrated ATSC tuner for free-to-air HDTV reception Device Color Black Interfaces Analog RGB, Composite, Component, S-Video, HDMI, antenna Viewable Size 46" Viewable Size Aspect Ratio 16:9 aspect ratio Panel Resolution 1366 x 768 panel resolution Response Time 8ms Typical Response Time (gray to gray) Brightness 500 cd/m2 image brightness Contrast Ratio 1000:1 contrast ratio Maximum Viewing Angles Horizontal / Vertical 178° horizontal / 178° vertical viewing angles Tuner Integrated ATSC/NTSC/QAM tuner Speakers Integrated Stereo Speakers Audio Amplifier Integrated 9 Watt per channel audio amplifier Front Panel Controls Power, Menu, Up/Down (Channel), +/- (Volume), Input Select Composite A/V inputs (2) S-Video Inputs (2) Component Video Inputs (2) Antenna Inputs (1) DB15 VGA Inputs (1) HDMI Inputs (1) Audio Outputs (1) Left and Right Stereo RCA Jacks; (1) S/PDIF digital Wall Mount Optional - VESA 200 mount Stand Includes tabletop stand Dimensions (WxDxH ) 46.06" x 5.39" x 32.74" (with stand) Weight 79.39 lbs. Power Supply Integrated power supply Voltage Required AC 100/220V (50/60Hz) Power Consumption Operational ( Standby ) <290 Watts Manufacturer Warranty 1 Year Limited Warranty
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    EM1 Crew Member
    SOLD
    H-T EM1 Crew Member
    tat was fast...
    that's what she said.
    but i know how much he got it for and if he did get $675 he got himself a pretty good profit you can ssay...
    EM1 Crew Member
    H-T EM1 Crew Member
