Honda Civic Ex 2001
Haven't been on the forums for a while. Last time 2006 . Thought I'd come back and ask a few questions to everyone. So here is what had happened...
I had been driving my car and I heard some popping noises from the front axels. I was like okay, maybe my suspension. I got some Eibachs adjustable springs and was like, okay not resolving the issue.
Called a few friends of mine and some said my axel. So I bought new axels and replaced them. When I had replaced the front passenger, I had a leak. transmission fluid was actually flowing out and slowly. I was very busy with work and decided to myself I'll refill it later.
Month and Months go by and I realize my gears are getting harder. I took it to a shop and asked them to top-off my transmission fluid and all was good. My problem was though it still had a leak so it was only temporary.
When it got low again, I took it to another shop. This because when it gets low in fluids it would pop out of 5th gear when accelerating. Only 5th gear was the issue. I figured it solved it the first time, I haven't heard anything to indicate anything else. This fix that worked the first time didn't resolve the issue.
So, I decided since my clutch is giving me difficulties getting into gear, which I figured okay 100k miles factory clutch, I'll get it replaced. Got it replaced and had them refill my transmission fluid. Apparently we found out that my car takes motor oil from a 2008 Car Information Book, states that my car takes 10w30. So I was like okay lets go with the book.
Well out of all that, the issue still exists. After I got my clutch and the new fluid. Since it was still having the same issues I've decided to get GM Syncromesh because I heard so many good things about it. Also, checked other forums and some guy had the same issue and he also had replaced a CV-Axel. Didn't work.
After that didn't work. I decided to find out why I had the leak. I took out the axel and took it back and said it was to short. Apparently that was right. It was an inch and a quarter shorter then it should of been. It was the same part that they gave me just a manufacturers defected part.
I called another friend of mine. I told him this story. He tells me that since so many fluids have been mixing together, its not good. I agree with him. It probably is having an effect on it all. I called the first place where I got the fluid where it fixed it the first time. Apparently it was Automatic Transmission Fluid. The one after that was Motor Oil cause it was as fluid as motor oil when I was changing it out. Anyone got any ideas? Or where I can go to get my transmission completely flushed out?
I've called a couple of places but all want to say its major damage. I can see it being major damage if it didn't hold at all. I drive home from Atlanta in 5th gear playing with the gas when I feel it will let itself loose and pop out. It works fine just not holding like it should.
Anyone got any ideas or suggestions? I'm up for anything.
