Results 1 to 40 of 68
Thread: FS: '95 LS-T 4door civic
    too many projects
    Greensboro, NC
    Default FS: '94 LS-T 4door civic
    * Name: David Willis
    * Means of Contact: pm or 336-554-0008
    * Vehicle Year/Make/Model: 1994 honda civic 4 door
    * Miles:190k on body 65k on motor and trans
    * Price: 7500.00 or obo
    * Title: Salvage or Clear? clean and in hand
    * Vin # 1HGEG855XRL028034
    - Interior:8/10
    blitz turbo timer
    avital 4400 alram with remote start and pager
    jdm console houses 5 gauges
    autometer elec. oil pressure
    autometer elec. water temp
    autometer elec. fuel pressure
    aem uego wide band
    autometer boost gauge
    new door inserts
    new trunk false floor
    rear deck under cover
    - Exterior: 7/10
    amber corners
    1/2 clear 1/2 red tails
    8k hids
    - Stereo & Nav:
    alpine 9886
    jl 4 channel
    alpine typer components and seprates
    dynamat front doors
    - Suspension: itr 5 lug
    gsr upper front strut bar
    no name rear upper strut bar
    no name c-pillar sturt bar
    drop zone struts
    skunk2 springs
    ss brake lines
    cross drilles and slotted rotors
    wicked front upper adjustables control arms
    wicked lower adjustable in the rear w/ wicked lca's
    - Wheels: rsx wheels with brand new nexxens 205-40-16
    - Egine: LS-T 2000 b18b and ls trans
    aem fuel rail
    aem cam gears
    dc sports shift knob
    b&m ripper shifter
    nology spark plug wires
    stage 2 clutch masters clutch
    fidanza 8lb fly wheel
    skunk2 pro series intake mani
    hondata inatke mani gasket
    avid billet motor mounts
    hondata s200/b
    walboro 255 fuel pump
    Brand new turbonectics t3/t4 62-1 63 trim
    full race equal length manifold
    3" full race down pipe
    fmic
    rfl bov knock off
    tial knock off waste gate 44mm
    10lb tial spring
    dsm 450cc injectors
    engine damper
    gas hood shocks
    morso oil pan
    ss sending and return oil lines
    dss stage 2 axles
    typer r crank pulley
    new honda timing belt
    new honda water pump
    new clutch slave on tranny
    polished alum. radiator
    polished alum. over flow tank
    mild wire tuck
    semi polished block and tranny
    Vibrant full 3" tubo back exhaust
    3" elec cut out
    new tb gaskets
    new valve cover gaskets
    new plugs
    honda tranny fluid
    mobil 1 10w30 and honda filters is all that goes in it
    The Good:
    It has been tuned by mark up at turbo tunes on 10 lbs daily driven
    250whp 200 ftq runs real good,
    The Bad:
    Time to let her go, needs some paint clear coat is peeling,
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    11 camry se
    99 cbr 900rr on n2o
    97 accord h22 on 25psi
    06 scion xb
    01 expedition
