Thread: performance tires
    Bender A. Rodriguez
    Macon
    Default performance tires
    I've got a set of Hoosier A6's size 225-50-15 that have about 50 cycles on them and a set of Advan A048's size 225-45-16 that 2 are about at the shaved height and 2 are slightly above with some high air pressure wear down the center. $100 for the Advans $80 for the Hoosiers. They've just been sitting in the corner of my shop for the summer so its time to get rid of them.
    Attached Thumbnails Attached Thumbnails -picture-035-jpg   -picture-036-jpg
    Ryan Reynolds
    im by the mall of ga... would i have to drive to macon?
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    Bender A. Rodriguez
    Macon
    Forgot to say I'll be in Atl. in my truck this weekend so if anyone wants these tires I can bring them with me so you won't have to drive all the way down here to pick them up.
    Ryan Reynolds
    I need those Advan A048's size 225-45-16 by saturday... Call me at 404-579-5745 so we can work it out....
    2009 zx10R
    2005 919
    Bender A. Rodriguez
    Macon
    I will call you later this afternoon and we can work it out. I'm already coming up saturday and probably bringing the slicks so that would work fine.
    Ryan Reynolds
    Ok just please try to make it early.. As i need to mount 2 of them , i am making them work as my slicks for tuner fest... I cant fit anything under a 16" rim so this is my best bet. You think they will work ok?
    2009 zx10R
    2005 919
    Bender A. Rodriguez
    Macon
    I'll see what I can do about the time but I can't promise anything at this point. They should be good drag tires once you warm them up. They like to be around 140-150 degrees for best traction.
    Ryan Reynolds
    Quote Originally Posted by Cool Cat Racing
    Sweet ... With 300+ whp i think i can get some heat in them....As long as i can get them by 2 or 3 ish i can make it work....
    2009 zx10R
    2005 919
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    simon simon...hoosiers
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    ALL CAPS JITB's Avatar
    I take it the hoosiers arent too safe to be driven on daily?
    ^que woudl it be safe to drive on the hoosiers every day?
    Bender A. Rodriguez
    Macon
    I drove them to some of the events that were close by but since these are the A6 compound they will not last very long if you do that much. Its not so much about the tread on an R comp, its heat cycling. Each time you drive the car its a heat cycle if you get them up to temp and they will start to get rock hard long before they wear out.
    Ryan Reynolds
