Results 1 to 5 of 5
Thread: installing rpm tach
    Certified Gearhead OWN3R's Avatar
    Default installing rpm tach
    well im trying to install a small rpm tach on my rb25det in my s13 and i tied it into one of the ignition coils like it said in the instruction... well that didnt work so i was wondering if ne one knew another way or something
    SwiperNoSwiping!!
    heres how it goes:
    red wire - tap into car's power. But, it has to be a power source that turns off when the car turns off otherwise you'll run out your battery when the car is off. Lol, theres plenty of other things to choose from other than the ignition coil, just look around a little bit and you'll find something.
    black wire - ground
    green wire - tap into rpm signal wire
    and there you go. Thats all there is to it.
    u remind me of a wigger !
    Woodstock
    On some you have to snip a wire or 2 depending on 4/6/8 cylinder I think......
    SwiperNoSwiping!!
    Depending on which brand you buy, it can just be a little switch in the back of the tach to select between 4/6/8 cylinders......
    cool thanks guys ill try that
