Results 1 to 19 of 19
Thread: honda ppl...F22B or H23A1
    14K
    northside
    Default honda ppl...F22B or H23A1
    WHICH IS OVERALL BETTER ENGINE(POWER WISE AND MONEY WISE)
    This is being swapped into a CB7 2 door.....thanx reps will be given
    F22B
    This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A,.
    Specifications
    * 2.2L
    * Bore × Stroke: 85.0 × 95.0 mm
    * Displacement: 2156 cc
    * Valve Configuration: DOHC, 16 valves
    * Compression ratio: 9.3:1
    * Max power: 166 hp (119 kW) @ 6000 rpm
    * Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
    H23A1
    The H23A1 was an increased-stroke, non-VTEC version of the H22a, designed for the North American and UK market 1992–1996 Honda Prelude Si. It shared the same Fiber Reinforced Metal (FRM) cylinder wall liners with the H22a.
    Specifications
    * Bore x Stroke: 87.0 x 95.0 mm (3.74 in)
    * Displacement: 2258 cc (138 cu. in.)
    * Type: In-line 4 cylinder, aluminum block and head
    * Compression ratio: 9.8:1
    * Max power: 160 hp (119 kW)
    * Max torque: 163ft·lbf (207 Nm)
    * Redline: 6500 rpm
    * Engine Control System: Honda Systems PGM-FI with port fuel injection
    * Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
    Kennesaw, GA
    H23
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Wheres the money?
    McDonough
    h23
    At Home
    I think both are answers are right and wrong.
    What kind of setup are you looking for? N/A? Boost? Spray?
    What The Hell
    Kennesaw/Acworth
    i have one of the F series in my car but its bottom of the line
    ive always heard that H series were better so i would say go with that
    Senior Member G.C's Avatar
    Forgot
    the f22b your talking bout is JDM f22b. And i believe they made 160hp. if your going to boost go jdm f22b. you can boost the **** out of that motor.
    :idb:
    x2 F22 is good for nitrous or turbo great motor!!!! H23 weak!
    Quote Originally Posted by G.C
    Crash
    Snellville, GA
    what the guy above me said
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Respect my Authority SilverSurfer's Avatar
    The Barracks
    i go with the f22
    say no to the h23, im not a big fan of the f22b either but i would rather have it than an h23
    About to approach beast mode
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    the f22b and the h23a have almost the exact same block and the exact same sleeves they like boost about the same just the f22 more bc of the lower compression...... if you want to go boost take the existing f22a1 and find a h23 head and put it on it..... then you have a Frankenstein motor with iron sleeves instead of frm sleeves.... but if you are not goin stricly boost and a clean daily i say h22 or h23
    NO NWS
    GetItFixItFlipIt Timinater's Avatar
    the heads are almost identical blocks are the major diffs. f22b has iron sleeves(thick as sh.it) holds up to 350whp safely on those sleeves. imo you dont need much more than that in a fwd car. only disadvantage to f22 is getting parts like the timing belt, you need the ecu also or to fabricate a knock sensor in for the h23 ecu. just do some research. i bought one from G.C the guy that posted in this thread, and he said it ran fine, but he sold me it after he broke it. one of the cam gears broke and f.ucked up the head, dont buy anything from him, he is shady as hell. also he wont answer my calls, great guy, not. gl though do some research!
    Try my 2.2 Imadaman's Avatar
    Rome
    f22b
    All about them Dirty Birdz
    jonesboro, ga
    Quote Originally Posted by Timinater
    h23 ecu will power the f22b... the h23 has a knock sensor it is the f22b that does not it has to be drilled and tapped which every motor selling site does that for you..... the timing belt and the water pump is the exact same as the h23... that is what hornsby and the guys at acura honda specialist used and i had no problem.... and from what i read the iron sleeves in the jdm f22b block is a myth that people get confused with the f22b1 that comes in a prelude s
    NO NWS
    Quote Originally Posted by 93ludew/h22a
    ok, your a f.ucking dumb ass. pull both motors apart and learn something. f22 has 126 teeth on timing belt h23 has 127. 1 tooth makes a big diff, also waterpumps are different. oh and putting the knock sensor in isnt hard, but goodluck finding one for cheap, most go for over $100. you need to research before you open your mouth
    Deuce Deuce BB1_Luda's Avatar
    H23a1
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    f22 would be my selection of the two
    but why not a h22a?
    AKA HIZDAWAY
    The Barracks
    Quote Originally Posted by ACCORDPRIDE
    but why not a h22a?
    x2
    jonesboro, ga
    did my research i had the jdm f22b in my prelude b4 i swaped it already pulled the motor and took it apart..... and i am a dumb a$$ when the guys at acura honda specialist are the ones that told me it would work.... that is the only place i would ever take my car to as shops go that is all i am saying is that they will work and i had it done a good 2 yrs before i did my swap and i did my swap bc the kepy broke on my crank shaft that is how i know my info
    NO NWS
