Results 1 to 40 of 47
Thread: clutchless shifting
    DUH-KYOO-LUHHH
    Default clutchless shifting
    anybody on here do it/know how to do it?
    i can do it into all gears except 5th... for some reason my car doesnt seem to like it from 4th to 5th.
    tawksick. toxxxic's Avatar
    Roswell
    i need to learn ... my throwout bearing is going bad =( the car stalls out almost every time i push in the clutch lmao
    in dabuilding
    i heard that will kill your tranny tho
    DUH-KYOO-LUHHH
    haha yeah, i would say thats bad. mine makes a sh*t ton of noise when i let off the gas while im in gear. at least i think thats what the noise is...
    all you do is pull the trans out of gear as you let off the gas and the gearbox unloads, and gently hold a LITTLE bit of pressure on the shifter and when the rpms match it will just fall into gear. its pretty cool. you can downshift like this too but i dont usually.
    Middle, Ga
    I did it in my dads camaro a few times! Oh and he taught me how to drive a semi truck, and once you get going you shift without the use of a clutch.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    DUH-KYOO-LUHHH
    ^^ well arent you phucking cool!! i learned in my miata. i do it sometimes when i get lazy.
    Middle, Ga
    Quote Originally Posted by jesse4846
    Of course I'm cool!.....lol
    "Damn, Its Tyler"
    DUH-KYOO-LUHHH
    Quote Originally Posted by dabuilding
    if you slam it into gear and let it grind until it catches, yes.
    if you do it the right way, no.
    bojangle JDMaccord's Avatar
    that happened once wit my old accord by accident..... was trippy haha
    g2 - gear3
    Looking for a professional photographer Gwinnett area but can meet just about anywhere!!!! Hit me up
    depends on how lazy i am. im able to do it in all gears. the big question is WHO CAN DO THIS DOWNSHIFTING(i can)
    DUH-KYOO-LUHHH
    i CAN but i havent perfected it.
    i can do it in all gears but it likes to grind going into 5th for whatever reason, so i just clutch 5th.
    Northwest Georgia
    is this in some type of race car? ...or the daily driving style.
    the proper way with a race car would be a dog box with a delay box and strain gauge.
    DUH-KYOO-LUHHH
    Quote Originally Posted by SPOOLIN
    no, just my DD. i know all that but none of that is worth having on a mostly stock DD miata... lol
    DUH-KYOO-LUHHH
    Ride with droptopdrifter some time
    It is bad on the synchro's, any time you aren't rev matching and seamlessly changing gears it is prematurely wearing parts out.
    I commuted from Gainesville to Buckhead for 5 days without a clutch in my Integra, only using the pedal to start off if i got caught at a light...that was an entertaining week!
    Even more exciting was a 8am commute from Gwinnett to the other side of Smyrna with with NO brakes...I didn't have anyone to help me bleed them after replacing a couple brake lines but had to get to work lol.
    Miata OG Roadster's Avatar
    Covington/Decatur
    In the Miata, that's probably gear lash, and there's nothing you can do about it. It's faint when the car has full interior, but take the carpet out and it gets loud. Put a lightweight flywheel in it and it'll be almost unbearable. I replaced two transmissions, throwout and pilot bearings, and tried different tranny fluids before finding an article about the real cause of the noise. In the end I had to put a loud as hell exhaust on my previous Miata so I couldn't hear the damn tranny clattering.
    Quote Originally Posted by Roadster
    lolol, wisdom comes from experience and what doesn't kill you will only make you stronger!
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Ive done it. its more or less fun to say to ur friend "hey watch this" and have them look at u like ummm did i miss something lol
    but my accord didnt like me going into 3rd wit out the clutch(i have no idea why tho, tranny had a fresh rebuild)
    the smoothest iv ever done it was in my friends 97 cellica. dono why but it went into every gear perfect.
    T-durr
    haha mine did the same thing it will into every gear except from 4th to 5th lol.
    if u try from 4th to5th it will just stall. lol
    DUH-KYOO-LUHHH
    i was thinking that too...
    mines pretty loud, even with the full interior. the only time its "faint" (depends on your definition of faint i guess lol) is with the top down.
    i do it in the teg sometimes, mainly just to show someone that its possible.
    downshifting though i have to rev it up in neutral to match the revs then it will drop in...i think thats how its done anyway isnt it?
    It just sounds dumb. The clutch is there, why not use it?
    My clutch master is on its way out, so I'm clutchless shifting as much as possible untill it comes in on tuesday.... hopefully Ill make it
    Fayco
    lol ^^ good luck bro!!
    and 87 i do it to show noobs u can shift wit out the clutch lol
    T-durr
    ALL CAPS JITB's Avatar
    i wouldnt do it in a stock mazda tranny... there not the strongest pieces of equipment!
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    I do it going all the way up and back down the gears. If you match your RPM'S with your wheel speed, you will only need to use the clutch when you take off from a stop. That what we Truckers refer to as "Floating Gears".
    N/A>>><<<BOOST
    Paint Guy Ricer's Avatar
    Petoskey, MI
    Quote Originally Posted by Vtak
    how do you stall your engine going from 4th to 5th? ...unless you're trying this at like 5mph i'm not seein how that is possible
    Stang Mod slostang's Avatar
    Southside
    Quote Originally Posted by Fast-Tech
    x2 I learned in my dads semi too.
    Southside of The Jungle
    I say clutches were made for a reason...My opinion
    Let's say you're in the middle of an endurance road race, or even just going to work, and your clutch master or slave cylinder go out. Do you call AAA for a tow or continue driving?
    You can start/launch a car off with no clutch, it's hard on the starter but it's more than possible...the rest of the gears are easy.
    The clutch is there for a reason. USE IT. This is one of the reasons I dont like buying a used car...
    Fayco
    lol just dont buy a car from one of us then
    T-durr
    Endurance race .Good thing about my car I dont have a slave. So once again clutch was made for a reason.My OPINION!
    Quote Originally Posted by tdurr
    T-durr
    I'll keep that in mind
    x2
    DUH-KYOO-LUHHH
    well what if your cable breaks?
    and the clutch is there to get you rolling. if you dont have to use it between gears, why use it? its not like it hurts the car unless you suck d1ck and grind all the time
    If shifting like that doesnt hurt your car why did they create a clutch again.
    I still say it sounds dumb. How many people do you know who've had the clutch just plain stop working. I'll practice clutchless shifting WHEN that happens, until then, my clutch works fine, and you should already rev match speeds anyway, so use the clutch.
    DUH-KYOO-LUHHH
    to make it smoother to leave a stop and to make it EASIER to shift.
    its not like im just slamming the car into gear people... go try it. i promise you it wont **** your car up. ill bet you money that nothing will happen if you do it correctly.
    DUH-KYOO-LUHHH
    Quote Originally Posted by 87 Turbo II
    actually, it happened to me in panama city on spring break. my slave completely went out and i had to keep the reservior topped off and pump the clutch to build up enough pressure to get it into first, and then floated all the gears after that.
