Thread: MOTOR MOUNT QUESTION!
    FLOSSIN' MR.EM1's Avatar
    Default MOTOR MOUNT QUESTION!
    i have a 99 si i need to know if i can use my same motor mounts so i can put a 94-01 LS motor in it and can I use the INTEGRA Prothne motor mount insert kit for my civic motor mounts bc they dont make a full kit for a civic si. I think they will work just to need to know for SURE...thank u
    FL
    college park
    i think you should be able to since its b series
    why you going ls when you have the b16a2 ?
    now with LSD
    my b16 has 212K its in really good condition but its still high for boosting...and an ls is cheaper
    FL
    yes u can
    Cambodia
    You'll have to run the b16 driverside engine mount bracket to work with engine mount.
    Quote Originally Posted by iNsTuN nOoDoH
    im talking about the mount INSERT..im confused
    FL
    Cambodia
    Oh... I guess I read that wrong then... my bad.
    What I understood was...
    You wanted to use your stock mounts with the LS motor and you were confused whether you could or couldn't use them. So I said you would have to use the SI timing belt side bracket in order to use the SI mount. As far as the inserts go.. I don't know.
    IA Member BMFH07's Avatar
    Columbus, GA
    yea they will
