need info... - IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community
Go Back   IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community > CAR FORUMS (Tech Area) > FORCED INDUCTION
FORCED INDUCTION Supercharger & Turbo Forum
Reply
Thread Tools Display Modes
  #1
Old 07-31-2008, 07:53 PM
Master Shake's Avatar
Master Shake Master Shake is offline
shakin it down
Master Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the monthMaster Shake member of the month
Default need info...
i've been workin on a zc single cam for a little while now, i do plan on boosting it, and i was wondering what would be a good turbo choice for the application. i'm lookin for something around 350+whp (meaning if i hit 352whp then i'm done). i know i could get more, but i'm not worried about it, i'm just lookin for something i can play with since i already have a dd and a bike as a gas savers.
thanks for the info.
edit.
what are the differences between fuel injectors? i've been looking around for some 440's or 550's. should i get the saturated or what? which would be best for performance and reliablity? more so for reliability.
Old 08-01-2008, 02:36 AM
SiRed94's Avatar
SiRed94 SiRed94 is online now
Don Mon
SiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the topSiRed94 on the way to the top
gt35 and a built bottom end...
__________________
Old 08-01-2008, 02:38 AM
slostang's Avatar
slostang slostang is offline
POST WHORE
slostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KINGslostang is the POST KING
Quote:
x2. a single cam with that much power won't be very reliable.
__________________
aye ess aye pee
Old 08-01-2008, 10:32 AM
shakin it down
Quote:
its why i'm making it a weekend car. i have a 82 accord i'll be driving daily.....or really when its raining and i also have a 250 ninja that i'll be using for most of my dd since its so good on gas.
i thought the gt35 was rated for like 5-600+hp?
Old 08-01-2008, 12:04 PM
patrick4588's Avatar
patrick4588 patrick4588 is offline
Slow DC
patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)patrick4588 has 700+ rwp (rep wheel power)
get a 60-1 and 550cc injectors. 440s will be at a very high duty cycle with a super high fuel pressure to reach 350whp
__________________
GCO Member
NRA Member
Glock 23, 29sf
DoubleStar/RRA AR15
Old 08-01-2008, 03:47 PM
shakin it down
Quote:
should i get saturated injectors or no?
Old 08-01-2008, 06:04 PM
SiRed94's Avatar
Don Mon
you put 350 hp on a stock single cam and I promise a rod will exit the block...
__________________
Old 08-01-2008, 06:12 PM
SiRed94's Avatar
Don Mon
and that just means that they are capable of producing and operating at that amount of HP.... they will work with lower boost applications as well and they spool fairly quickly...
__________________
Old 08-01-2008, 09:46 PM
Slow DC
what year car do you have? i know some of the old hondas have peak and hold injectors and use a resistor box stock. i know the 94-01 tegs use saturated, and so do the 92-00 civics
__________________
GCO Member
NRA Member
Glock 23, 29sf
DoubleStar/RRA AR15
Old 08-02-2008, 12:35 AM
xdavidscenex's Avatar
xdavidscenex xdavidscenex is online now
lolgarage
xdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SATxdavidscenex scored 1600 on the SAT
i think 35r is too much for 350whp D.
Old 08-02-2008, 07:47 AM
bananuta bananuta is offline
bananuta has a little shameless behaviour
Come and see me !!!
Old 08-02-2008, 12:19 PM
shakin it down
its just the motor and tranny right now, but it'll end up in a 92-95 civic.
i will NOT be running the stock bottom end. i'll be up upgrading the rods, crank, bearings, and whatnot. but i will have the stock piston heads out of the d15z1 block. they seem to have a lowering compression then the stock b7 blocks. but to assist in that i will plan on installing a block guard to try and protect the bottom end, if something should go wrong. and i'm making sure i keep a spare block so if it does somehow go out, i have a back up.
i thoguht about using a gt2860r or a gt2871r with 440cc injectors. and since i would to keep a low key on me boostin i was gonna fab something up for a a/w IC.
Old 08-03-2008, 11:27 PM
UBERGRMN UBERGRMN is offline
IA.COM NOOB
UBERGRMN what a nice guy
Quote:
Im making 350whp with a 35R on a stock H22. its big but im goin big soon! (built bottom end)
Old 08-04-2008, 06:06 PM
lolgarage
yeah i made 266whp with the 35r on a LS, could have made more but my fuel pressure starting dropping to 32psi.
Old 08-04-2008, 06:17 PM
lolgarage
Here Tran..
JFK78's hatch
http://speedfactoryracing.net/
http://www.honda-tech.com/zerothread/2035990
http://www.youtube.com/watch?v=azwzEghDX8U
now heres Sl@sh off of onecamonly
http://onecamonly.com/showthread.php?t=1353
Old 08-08-2008, 09:27 PM
scttydb411 scttydb411 is offline
IA Junior Member
scttydb411 a house hold namescttydb411 a house hold namescttydb411 a house hold namescttydb411 a house hold namescttydb411 a house hold namescttydb411 a house hold name
your choice of turbo will be good for a not so laggy setup. you'll need at least 550cc, but i would recommend 650cc so you don't have to run higher duty cycles. get saturated inj so you don't have to run a resistorbox.
__________________
Old 08-09-2008, 01:46 PM
shakin it down
thanks for all the info guys, i'll repped all that i can
and for the
UPDATE!!!!
i'll be getting a 95 ex coupe here soon from a friend know around here. car is pretty much ready for a swap with wire tuck and all already done!
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Import Atlanta,LLC /This, or any file, may not be published, broadcast or otherwise distributed without the prior written permission of ImportAtlanta,LLC.
