- Power Mods help!?!?!?!
help!?!?!?!
93- B18b1
pr3 camsi am getting rdy to torque down the cam caps and i relize theres a lot of freeplay in the cams from side to side about a half inchs i know that the distributor will stop that on one but wat about the other cam>? there a shim kit i buy or wat? when i torque it down will the free play stop?
- Rep Power
- 23
pr3 as in b16 cams? as in you are are putting b16 cams in a non-vtec head?
- Rep Power
- 0
If you meant to say PR4 cams then this is normal when the cam caps arent on. The cam cap at the very end, on the dizzy end, has a grove that holds the cam in place from shifting side to side.
- You may not post replies
- You may not edit your posts
Forum Rules
