Results 1 to 13 of 13
Thread: Emissions
    Default Emissions
    I have a 94 civic dx with a JDM sohc non-vtec zc motor in it. The motor has about 60k miles on it, and everything works fine. I took it to get emissions done, and FAILED!
    25/25 test 50/50 test
    Reading Allowed Result
    HC ppm 19 147 pass
    CO % 0.00 0.82 pass
    NOx ppm 3174 1072 fail 4306 1186
    RPM 2779 3000 max
    CO+CO2% 14.54 6.00 min(pass)
    On both tests, the NOx was 3x the legal amount. They said change the O2 sensor( it only has one: on top), EGR valve( doesn't have one), or the timing is off( it's perfect).
    What can I do to get the NOx down? Is there anything that I can do? PLEASE HELP!!!!!
    Crash
    Snellville, GA
    your 02 sensor is bad. go to like autozone or oriellys and get a new one man and then youll be fine.
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    change the 02 sensor .but just my .02 g/l on getting it pass
    Quote Originally Posted by suprapower
    TY! i'm keeping my fingers crossed. btw.... i'm not a man
    Stang Mod slostang's Avatar
    Southside
    jdm motors were never made to pass any sort of smog emissions so getting it to pass might be a challenge.
    Winder,Ga
    I know but 3x is alot...just an o2 shouldn't do that????? I hope it will pass!!!!
    Southside
    do you have a hollow cat?
    Winder,Ga
    not that I know of....I hope not...only time will tell...
    Southside
    yeah your problems are more than just an o2 sensor. I had a burnt o2 sensor and a hollow cat and didn't come close to failing as bad as you did. I'm stumped.
    Winder,Ga
    IDK....we will see tommorrow....
    Quote Originally Posted by masanomi3
    that's MY car!!!! not your car!!!!!!!!!!!!!!
    Winder,Ga
    HAHA....I'm helping u.....
