Results 1 to 17 of 17
Thread: getting head milled, is it POSSIBLE to boost later?
    SwiperNoSwiping!!
    Default getting head milled, is it POSSIBLE to boost later?
    I know, boosting and getting my head milled are going down two entirely different paths as far as making engine power is concerned, but what i was wanting to know is if i get my head milled down to a certain point and my engine will have a higher comp ratio, can i still boost on that particular head or should i re-install a stock head to bring the CR back down for boost?
    u remind me of a wigger !
    Duluth, GA
    joel...come on man no motor stuff get that DB lookin' sexy first
    SwiperNoSwiping!!
    Quote Originally Posted by Captain-Obvious
    lol sorry i gotta get it fast first!
    Plus, ive already got a 2nd head to work with, so i figure i might as well see what kind of power i can try to regain from a bit of a build. lol plus im only makin 96whp. Thats less than a Honda FIT.
    Crash
    Snellville, GA
    what kinda of setup do you plan on running on it?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    SwiperNoSwiping!!
    stock pistons/piston rings, 8 - 10psi Garrett T25 turbo, new valve seals, dual valve springs, OEM headgasket, chipped and tuned by Scotty, port/polished head, new engine bearings, freshly honed cylinders, and milled head(?).
    EDIT: forged pistons/rods, eGay turbo kit and replace the charger with Garrett T3/T4 turbo on 8 -10psi, new valve seals, dual valve springs, OEM headgasket, chipped and tuned by Scotty, new engine bearings, new rear main seal, freshly honed cylinders, HKS boost controller .
    Sound nice and reliable?
    Duluth, GA
    Quote Originally Posted by GM_TUNER
    alright fine...
    it really doesnt matter, sine you getting it tuned anyway. and plus your goin to make more power with the head being milled
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    MAY CAUSE CANCER Psycho's Avatar
    Standing Right Behind You
    I've never tuned a honda before. But I have owned several turbo vehicles. The one thing I can tell you, is that raising compression before you boost your car is a step in the wrong direction. The higher your compression is, the less boost you can run on your car, and the more likely you'll pop an engine. Instead of spending money on head work, buy a set of lower compression pistons and some forged rods. That way, when you do slap your turbo on, you can run mad boost, make a **** load of power, and not worry about blowing your baby up. The more money you spend on random crap, the longer it will take you to finish your build.
    SwiperNoSwiping!!
    Quote Originally Posted by Psycho
    AMEN to that one, it seems like thats all i've been doing lately....
    REPS!
    EDIT: so basically, what you are saying is, get more block/bottom end work done, rather than headwork.
    FLOSSIN' MR.EM1's Avatar
    low cr pistons/rings/rods, oem gasket, turbo FTW
    FL
    Norcross
    vtec head.. btw this is the primer hatch
    Senior Member G.C's Avatar
    Forgot
    That is true but you GAIN more power with LESS boost in higher Comp.
    :idb:
    SwiperNoSwiping!!
    Quote Originally Posted by j0nbunklah0m
    lol THE primer hatch?
    *i have no recollection btw...have i met you already? Are u the dude that was always complaining about how ur front tires are too fat in comparison to the back ones? I think i know who u are now...maybe.
    SwiperNoSwiping!!
    Quote Originally Posted by G.C
    Yeah, not to mention; withOUT boost, its more power as well. So, if i just get my head milled, ill have to run less boost. Oh, well. Either way, its more power to the wheels.
    I think ill get my head milled AND run forged internals and boost, that way itll be more power (but less boost) and i can still be not as concerned about popping anything. Not to mention, getting my head milled costs pretty much almost nothing.
    Newnan
    if your going as far as a fresh hone on the block, get sleaves then you are safe @ 10 psi at least with your high compression. make sure to put some good rod bearings in as well especially if your running higher compression
    SwiperNoSwiping!!
    Quote Originally Posted by TR_Accord
    If its possible to replace the sleeves in basically a "backyard mechanic" type setting, then i might think about it. I hear upgrading sleeves can get pretty expensive...
    Also, who makes a good rod bearing set?
    SwiperNoSwiping!!
    LoL...one last question for you guys;
    1st off, let me explain; my compression in my engine is very low. If i get my milled head and install it, ill be installing it on low-comp rings. What will happen if the thing makes my compression too high, after installing new rings. Is that possible?
