Results 1 to 15 of 15
Thread: k20 turbo rsx.
    Default k20 turbo rsx.
    what yall think about turbo the rsx?
    in dabuilding
    i think its a turbo k20 wich is good
    yea its a k20
    Vuong's Garage lxpaulxl's Avatar
    I had a turbo RSX-S. My first kit I had on was a Greddy Kit and made 261WHP. Very reliable and simple. My second kit I had made 421WHP and I ended up blowing up the motor due to failure of the oil pump, I got very unlucky. A stock k20a2 can handle powers up to and around 500WHP. I've heard someone making 600WHP on a bone stock motor but I'm not too sure if anything happened to the motor or not. Boosting a K20 is a lot of fun, but they have weak rods and oil pumps.
    Certified Gearhead atlxpat's Avatar
    atlanta
    Quote Originally Posted by lxpaulxl
    take his word for it, i have a piece of his block in my glove compartment
    Rome,Ga
    hey thanks for all the info on the rsx i think i am gonna turbo it...
    Norcross
    LOL Due To Fail...
    Buslengths behind you
    seems like k20 turbo done right,would not be cheap either
    kangarooster meadows
    Not necessarily, just depends on what kind of power you're looking to make. Whether IA will except it or not, ebay turbo kits are completely acceptable options for anyone looking to boost but keep it under control. Hell yea a boosted k20 is a good idea, but it can be complicated just like any other motor depending on what kind of power you're going for.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    but if you have an engine worth ~$4000 why the hell are you gonna risk failure on a $500 eBay turbo kit? Of course it COULD work fine with no problems ever, or it could end up costing a lot more in the long run.
    Who knows?
    Quote Originally Posted by hondabuilder
    True, it could. But anyone with enough knowledge about boost can run an Ebay kit no problem, lots of people do it. You dont boost the **** out of a motor with an Ebay kit, but it's not gonna blow your **** up on 10lbs. if you know how to maintain it.
    Suffolk, VA
    right, but anyone with enough knowledge to make the eBay kit work well, has enough knowledge to know its not worth it in the long run. (just imho)
    Who knows?
    Well in the long run the bearings and seals will blow up on you, but preventative measures can be taken to make it a reliable system.
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    u must have a type-s not just a base to hit these numbers
    o=(O_o)=o ChRiS's Avatar
    Quote Originally Posted by atlxpat
    Hey Pat I think some of the oil is still on my car LMAO. DONT TURBO IT!!!! ITS A HONDA! USE IT FOR WHAT IT IS *GOOD GAS MILEAGE* Paul probably got about 12 miles a gallon but if you do turbo it and want high numbers, i would definitley get a daily driver. GOOD LUCK! If you need the work done, go vist voungs garage
