Thread: Got a questions about metals?
    Question Got a questions about metals?
    ok im looking at buy some 2" drop spindles for my truck. there is 2 types of metal they are made in Steel and Ductile iron. i was wondering which one is better and would last longer?
    thank you in advance
    JDM TYTE AnthonyF's Avatar
    not being a smart ass, but google? Figure out the properties of each metal and what each consist of. I dont know so metals very well.
    -Ant.
    The Carbon Fibered R6
    Crash
    Snellville, GA
    I BELIEVE STEEL IRON WOULD BE BETTER BUT LIKE THIS GUY SAID I WOULD GOOGLE TO CHECK IT OUT FOR YOURSELF
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Certified Gearhead gijeff1805's Avatar
    conyers
    steel will be stronger...do you know what type of steel by chance?
    in dabuilding
    steel for sure iron is a softer metal i do believe
    Miata OG Roadster's Avatar
    Covington/Decatur
    Yeah, if you can find out what kind of steel it is, that would help.
    Ductile iron is just what the name says...ductile, flexible, not as brittle as standard cast iron. With hardness comes brittleness. Less hard = more flexible and more able to withstand shock. I'm not sure what the happy medium is for something like a drop spindle, as it carries a lot of weight and sees a lot of shock. Chances are you're going to want to go with the steel one either way as long as it's relatively mild, low carbon content.
    slick fricks sikfricks's Avatar
    ROME,GA
    forget the spindles get thornbeck bros control arms (suicidedoors.com)
    <img src=http://www.importatlanta.com/forums/image.php?type=sigpic&userid=19661&dateline=1274467236 border=0 alt= />
    IA Member BMFH07's Avatar
    Columbus, GA
    steel it takes more heat yet more wear and tear and last longer
