Thread: In the process of building my first Built LS....what cams should i choose??
    SwiperNoSwiping!!
    Default In the process of building my first Built LS....what cams should i choose??
    I've decided im going to build my motor somewhat.... I'd like to have a stock bottom-end, and built head and valve train only. Later on, i will be boosting the motor but only to 8 - 10psi for dailydriving.
    My goals for the motor are:
    -Max 300whp
    -able to safely rev and keep powerband beyond 7k (redline)
    -be reliable
    -able to rev much quicker than stock
    This is what i have so far, and what i have planned:
    -dual valve springs
    -port and polish
    -3 angle valve job
    -new valve stem seals
    -new head gasket
    -get head milled down (not sure how much, whatever is safe )
    -titanium retainers
    -oem valves
    -chipped and tuned by Scotty @ Mainstream
    How does this look? I am having trouble choosing a cam! What should i run?
    u remind me of a wigger !
    SwiperNoSwiping!!
    Also, could anyone tell me what kind of potential "all-motor" power this setup may make before boost is going through the motor? It will have new piston rings and a new headgasket when i get done with it as well.
    Dont waste your money trying to make power NA.
    you would be better off just buying a VTEC head and putting it on. Youll make more power with a VTEC head than you will with all that crap you just listed.
    If you are serious about going turbo, then most LS people need 404s and springs/retainers. Milling the head is the opposite of what you want to do, dont do it. Porting is a good idea, but it depends who does it.
    Personally i would jut buy one of the $300-350 VTEC heads on here, a skunk2 intake manifold, GE LSVTEC kit and swap it out. THen i would get it tuned and keep the revs below 8000 so your block doesnt let go.
    SwiperNoSwiping!!
    lol i dont want vtakkk tho
    but, who should i get to P+P it?
    EDIT: So, this will be it i guess?:
    -Crower 404 cams
    -dual valve springs
    -port and polish
    -3 angle valve job
    -new head gasket
    -titanium retainers
    -oem valves
    -new piston rings
    Well its your call you can either
    1) SPend a ****load of money and make almost no power gain
    2) you can spend a small amount of money an pick up 15-20whp
    They invented VTEC for a reason
    SwiperNoSwiping!!
    Okay, here is what im going to get:
    Crower cams
    Stage 2 - Turbo/Super Charger Special
    Specially designed specifically for forced inductionapplications.
    Features short duration, high lift for added cylinder pressure and good bottom end power.
    Advertised Duration: 270/235
    Duration @ .050": 203/203
    Gross Lift w/1.75: 469/469
    PS... i still dont want vtakkk :boobies:
    EDIT: I hope it will still run good/okay even if there isnt boost present
    Warner robins ,Ga
    x2
    on the 404's
    i need one.
    SwiperNoSwiping!!
    Quote Originally Posted by xdavidscenex
    x2
    on the 404's
    i need one.
    I read on another site that the 404s arent good for turbo though?
    http://hondaswap.com/engine-building...s-turbo-73301/
