Results 1 to 40 of 70
Thread: six7teen's random "Honda-parts-r-us" garage sale (50+ pics)
    chill six7teen's Avatar
    Columbus
    Default HONDA PARTS!! garage clean out!
    so ive decided the easiest way to do this is post a picture with the description/ price above it.. almost EVERYTHING is obo.. and i will not travel for under 50 dollars.. gas SUCKS and i have a very tight schedule!!! so here we go!!
    EF crx dx BLUE seats.. condition isnt great, or good...$35 $20
    Set of 92-95 2dr civic headlights... perfect condition! $45
    Civic/Integra (eg/dc) NEUSPEED upper strut bar.. also have what i think is the lower strut bar?? comes stock in integra's and bolts right into civics.. will include for free.. $100 $75
    Almost Full 92-95 civic 2 dr interior.. will part out if the price is right... this includes: door panels, rear panels, upper pillars, roof, black seatbelts, w/e else is pictured, and all the little crap needed as well... $100
    door panels are sold!
    EG/EJ civic SI door panel inserts! all parts will be included, but they need to be REglued or w/e it is you do.. $25 $15
    4-1 Bseries DC SPORT black header.. number 3 and 4 cylinders are bent up a good bit.. $50 $25
    Remanufactured obd0 ECU out of a 90 CRX dx (nonvtec) $75 $50
    One 12" "vanquish" 4ohm 600watt sub.. $20 $10
    VisonIK skinny 12 inch sub/box w/ built in amp.. amp needs a new resistor to work.. $25 $15
    Half-size radiator for 92-95 Civic.. NEW, only has 50 miles on it!!!! $50 $35
    Bseries for EG/DC driver side axle w/ ABS $51(Pending)
    Bseries for EG/DC driver side axle $50 (Pending)
    Optima Yellow Top battery (less than a year old and only on concrete for picture.. stored on a plastic cabinet) $85
    Dseries shift linkages w/ stock shifter and bushings out of a 90 civic hatch.. $10
    will inlude a BNIB set of energy suspension Urethane bushings (red) for an extra $10
    Two driverside clear corners for 2dr civic 92-95 $5
    92-95 2dr Civic rear trunk lid.. (insulated so it wont rattle) $37 $20
    PARTING OUT!!!
    JDM B18B LS head with 11,xxx ORIGINAL miles on it.. at 10,xxx miles, head was resurfaced, pressure tested, etc.. b18b1 intake manifold (IAC valve not included), ITR throttle body (tps broke during removal of motor), b16a fuel injectors, gsr fuel rail... LS dizzy with 8.5 mm wires.. g-power spark plugs... Web Stage 1 cams with DPR adjustable cam gears... VC is custom painted blue/purple with a pearl in it, polished letters.. only problem is when taking the cam holders out to remove from block, a few of the bolts decided to snap.. machine shop quoted $25 for removal..
    IACV- sold
    fuel injectors- sold
    Throttle body- pending
    cams/gears- pending
    SOHC non-vtec Valve Cover. Letters have been shaved.. Color is Red wrinkle finish with a blue pearl in it.. Valve cover seals are all Brand New and never used! $50
    G'Reddy Turbo Timer.. Came out of a EJ civic! comes with all wires and plugs.. Works great! $75 $50
    D15b2 crx Head Gasket. BNIB! $25 $10
    H4 HID bulbs 10k.. light appears as a purpleISH color! needs balast. $45 Pending
    if you have any questions, the best way to contact me is thru either PM or you can text me at 706-662-4098.. Thanks for looking!!
    ALSO, i will trade for parts, but not for many.. main things i am looking for right now is CRX suspension and an INVIDIA exhaust for a CRX!!
    LS seats SOLD
    Full size radiator for DC integra. ALMOST NEW!! Sold
    D15B2 longblock w/ tranny..Sold!!
    D16z6 shortblock.. pistons and rods have been takin out.. motor spun a bearing in cylinder 3.. has everything pictured.. all other internals are still in motor.. Sold!
    D15B2 DPFI head.. unkown condition.. Sold!
    D16z6 intake manifold.(good upgrade for your d15 motor) Sold
    Bseries Starter Sold
    Civic Master Cylinder Sold
    dseries flywheel Sold
    GSR wire harness SOLD
    Bseries for EG/DC half shaft ( needs seal) Sold
