Results 1 to 20 of 20
Thread: Brake lights ON?
    Arrow Brake lights ON?
    Well after trying to start my hatch after 2 weeks in storage it would not crank... of course I thought to my self its the battery, gave it a jump and started up without a problem. Now I didn't think twice about it till I saw the brake light on. Well I then I thought to my self I must have left the lights on when I stored it...? Went to turn the switch of and to my surprise it was already off. Well now what could the problem they stay on even with the car off and the key out the switch...? Anyone with the knowledge of this happening to them please advise thanks.
    Exclamation
    Look on the Brake pedal there is a little rubber stopper that is used to compress the stop light switch...It might have broke off.If so put a bolt an a nut an will fix the problem! Or the stop light switch needs adjusting!!! very easy losen the nut an spin in or out where the switch is off when pedal is up, an on when you mash down the pedal 1/4 ' an your good!!!
    Quote Originally Posted by GSRtegŪ
    Thanks Josh that exactly what it is I remember seeing little rubber piece on the floor mat and saying what the **** lol. Ok now were does that little ***** go at exactly?
    LAWRENCEVILLE
    beat me to it josh. check that rubber piece
    Hella stock member!
    Quote Originally Posted by silversol
    Yup that is now were does the nut and bolt go got a diagram?
    Look under the dash , yes it is a pain look up at the Brake pedal an you will see the switch where the Pintal of the switch is look on the pedal an its where the petal an the pedal touches...Throw the rubber peice away, there is a hole, get a 10mm bolt an nut, insert it in an your done, might have to adjust the switch though
    BTW I came by your house the other day, drove by an saw the Black coupe in the yard! I was going to stop by but had things I had to do!
    Thanks man will do.. now to find that bolt. REP
    What day was it I might have been home?
    Tried
    You must spread some Reputation around before giving it to JoshuaASE again.
    Just go get any 10mm bolt..Hell I think I used a 10mm bolt out of the off the Battery cable done on the tranny bracket an took it to AZ an got a nut when I was fixing someones car at AZ
    Cool will do thanks again Josh.
    LAWRENCEVILLE
    post whores lol
    Hella stock member!
    Problem is FIXED... remembered that I had another pedal set and took the rubber from there.
    good deal!
    good deal!
    Yeah also I saw that the clutch pedal had one what is that one for?
    Its clutch safety switch, It will not crank unless you press the clutch in!...When they go out in my cars, I just jump the connector with a paper clip an it will crank in Gear also so becarefull
    the one for the clutch is for ign. (its for safety, just incase your car was in gear)
    you beat me to that one too, dam it!!
    Thanks
    welcome
